Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Hoff Woohoo
    stevewhite71's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery level notification on active display
    I would like to see battery level on the active display. I was thinking an app that sent notifications or at certain levels would trigger that. Anyone know of an app that already does it? If not I'm sure it is possible to write that in tasker, correct?
  2. #2
    jim1405's Avatar
    Posts
    Global Posts
    30 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery level notification on active display
    +1
    I don't know if it is possible but would love to see this too.
  3. #3
    someguy01234's Avatar
    Posts
    Global Posts
    1,820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Best way is just to get a battery widget app: https://play.google.com/store/apps/d....batterywidget
    This app let you set alerts for different battery levels. You need to make sure to have it checked in Active Display's list of apps.
    I would prefer to do it using Tasker which allows more tuning and have it notify only when the screen is off, but it's also more complicated.
  4. #4
    jim1405's Avatar
    Posts
    Global Posts
    30 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks. I'll give batterywidget a try.
    I've never fooled with Tasker but if batterywidget doesn't do the trick I wouldn't mind learning how to use Tasker.
  5. #5
    4runnerbrett's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I used to have a galaxy s3 and lived on the little battery percentage but with the moto x I done have a issue pulling the task bar down and clicking on the person icon to check the battery.
  6. #6
    Ry
    Ry is offline
    Ry's Avatar
    Posts
    Global Posts
    14,565 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    IIRC, battery level is displayed on Active Display when it's below 15%. I haven't gotten that low recently but I'll keep an eye out.
  7. #7
    Hoff Woohoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Ry View Post
    It does. If I remember correctly it's a little red battery icon.
    Ry likes this.
  1. Mugen Power 2800mAh Battery Case for the Moto X
    By A895 in forum Moto X (2013)
    Last Post: 12-14-2014, 05:13 PM
  2. Thoughts on Verizon's "More Everything" Plan
    By GregMargie in forum Verizon
    Last Post: 02-23-2014, 12:12 PM
  3. Burn in on IPS display?
    By brandonx1000 in forum Verizon LG G2
    Last Post: 02-16-2014, 09:06 PM
  4. Replies: 1
    Last Post: 02-15-2014, 12:30 AM
  5. Active display & stock email client
    By NotFromHere in forum Motorola Droid MAXX
    Last Post: 02-14-2014, 09:04 PM
