Results 1 to 5 of 5
    sje2081's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Bluetooth audio quality issues
    I just received a new Moto X (ATT), and I've noticed some static issues with audio when connected through bluetooth in my car (Acura TSX 2009). I mostly use Pandora, but tested it just streaming Youtube and noticed the same issue. It doesn't seem to drop, but I am getting consistent, light yet annoying, audio static/pops every few seconds. I did not have this issue in this vehicle with my old Galaxy S2. Is this something that is related to the phone or the Android version (4.4.2). Should I bother trying to get a replacement? Did a search and saw some complaints about BT dropping, but I haven't noticed that as of yet. Thanks for any input.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,070 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Bluetooth audio quality issues
    Quote Originally Posted by sje2081 View Post
    Welcome to the forums.
    It is probably the bluetooth radio. Can you plug the X into your sound system with a wire?
    sje2081's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Meaning the BT radio is bad in the unit?
    I need to find an AUX cable to try....car has USB but I get an unsupported error when I try to use it.
    Thank you.
    sje2081's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For what it's worth if anyone does a search on a similar issue and finds this thread...
    I fixed it by purchasing a Kinivo BTC450 and syncing to that in my car...audio is perfect. Strange since my car's BT works fine with my old GS2 and my wife's GS4, but sounded like garbage with my Moto. But the Moto must be "working" since it works on this BTC450. Also, even on my car BT, voice calls were OK, only music audio was poor. I just have to chalk it up to some incompatibility issue between the Moto and my Acura's BT. Maybe it'll get fixed in a future update.
  5. #5
    cordoni's Avatar
    Posts
    Global Posts
    943 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Had same issue in my challenger. Ended up balancing speakers 3 ticks to tear on radio and problem went away.
  1. Bluetooth KeepAlive (to solve keyboard problem)... Has anyone used it?
    By SpookDroid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 05-04-2014, 07:09 PM
  2. Samsung Galaxy S4 Battery Issue
    By rond997 in forum T-Mobile Samsung Galaxy S4
    Last Post: 04-05-2014, 07:31 PM
  3. AT&T Note3 Gmail sync issue
    By OzarkArkie in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-02-2014, 02:08 AM
  4. kit kat issue?? or just galaxy note 3 issue HEEELLP
    By bethetruth in forum Sprint Samsung Galaxy Note 3
    Last Post: 04-02-2014, 01:11 AM
  5. Note 3 sync issues with music library
    By d_inalexus in forum General Help and How To
    Last Post: 04-01-2014, 11:48 PM
