1. Shaodong Lin's Avatar
    My Moto X stopped charging at 70% while it showed that phone was connected to the wall charger on the right top of the screen. After rebooting the phone, I can charge my phone successfully. My phone was only 4 or 5 days old, is there anything wrong with the battery? Thank you.
    06-25-2014 03:02 AM
  2. anaphora68's Avatar
    It might not be an issue at all.
    How hot was the charger? My MacBook will stop charging sometimes when the charger gets too hot.
    06-25-2014 04:49 AM
  3. ShoelerDroid's Avatar
    Until a new phone goes through a full charge --> days use --> recharge --> days use --> reboot cycle, my experience is the battery percentages are a bit off. I think the reboot had more to do with it than anything else.
    If it doesn't happen again, you're fine. If it does happen again, get them to send you a new one. Warranties rock and Motorola's customer service is EXCELLENT.
    06-25-2014 08:23 AM
  4. Snake Griffin's Avatar
    Mine did the exact same thing last week (have had it for about 4 months now), never happened before. Restarted it and didn't have any problems. Not sure what was wrong with it but so far so good.
    06-25-2014 03:37 PM
  1. Replies: 6
    Last Post: 07-09-2014, 12:17 PM
  2. The way to replace battery of XT910
    By Karl Thomas in forum Droid RAZR
    Last Post: 06-26-2014, 03:38 PM
  3. Battery problem on my GS5
    By Parham Goudarzi in forum Samsung Galaxy S5
    Last Post: 06-26-2014, 12:15 PM
  4. problem with unlocking the screen on experia S
    By kave ghelichkhani in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-25-2014, 04:12 AM
  5. Galaxy S4 drains battery while plugged in and charging
    Last Post: 06-25-2014, 02:39 AM
