1. hisense's Avatar
    Within Developer options (which you have but may be hidden)(rapidly press the Settings▶About Phone▶Build Number. Then exit one screen back and see it in the list) you can change the speed of animations. This means you can make things move visually faster.
    Settings▶Developer Options▶Window Animation Scale .5x▶Transition Scale .5x, Animation duration.
    Notice a UI speed increase now.
    Brady KEITH likes this.
    08-14-2014 07:02 PM
  2. pdaniel219's Avatar
    Just did this after reading your post. Definitely notice a difference immediately! Will this effect the battery life at all? And will it be for better or worse?
    08-14-2014 08:17 PM
  3. zedorda's Avatar
    These are settings that are commonly set to .5 in custom ROMs to fool newbs into thinking the ROM is faster than stock. Not all need to do this but it is a common practice.
    benhaube likes this.
    08-14-2014 08:37 PM
  4. benhaube's Avatar
    These sre settings that are commonly set to .5 in custom ROMs and fool newbs into thinking the ROM is faster than stock. Not all need to do this but it is a common practice.
    I know and I cannot stand when the developer claims the rom is faster and when I look the animation scale is changed.
    08-14-2014 09:57 PM
  5. ProParkour's Avatar
    I keep mine set to off. I've got no need for animation. Doesn't do anything other than look pretty.
    08-15-2014 01:24 PM
  6. PapaGary's Avatar
    This is a joke, right?
    08-15-2014 03:41 PM
  7. ProParkour's Avatar
    Not at all. I don't like the animations, so I turned them off. Having them off doesn't change my performance at all so why keep them on?
    08-15-2014 06:00 PM
  8. KWKSLVR's Avatar
    I keep mine off as well.
    08-16-2014 08:21 AM
  1. Battery Is Perfect On The OPO
    By SPS828 in forum OnePlus One
    Last Post: 08-15-2014, 05:02 PM
  2. Forgotten email used to set up android phone
    By Unregistered in forum Ask a Question
    Last Post: 08-14-2014, 07:15 PM
  3. how do I turn on the calendar alert?
    Last Post: 08-14-2014, 06:46 PM
  4. Is kies 3 the worst thing ever or am I using it wrong?
    Last Post: 08-14-2014, 04:56 PM
  5. Replies: 0
    Last Post: 08-14-2014, 03:27 PM
