I have a 2014 Moto X that I purchased in February, and I only used it for 2 weeks as a daily driver after I bought it. I switched back to my iPhone because the battery was draining very fast. I could only get about 3 hours of screen on time if I was lucky, and this is with screen brightness at 50%, NFC off, and a stable WiFi/Cell connection. It would also drain about 2-3% per hour on standby.
I have recently picked it up and started considering it as a daily driver again. I've carried it alongside my iPhone, just without a SIM card installed. The battery life had improved slightly on Android 5.1 for me, but even with Airplane Mode on, Bluetooth off, NFC off, and a searching WiFi connection while I'm driving, it drained 14% in 3 hours.
Is there any way to fix the battery draining so fast when not connected to a WiFi network? I have tried wiping the cache partition, rebooting, Greenify, keeping Airplane Mode on, and everything else just shy of a factory reset. I really want to use this phone as a daily driver again, but I need to fix these problems with the battery before I start using it again. Anyone else having similar issues with battery life or tips on how to fix this?
