Dont know if this helps anyone, but I have the same issue - I'm based in Scotland, UK. I found that if you create a new contact, then save it through Google: My drive, it stays in the phone for at least 20 mins so far.
If you can save your contacts as a vcf list, see it you can import that list into Google. Keep the file, you will have it for repeat tries if necessary. If it does enter successfully, then you should be able to edit contacts as normal and you will have to. Vcf keeps number and name only. No ringtones or addresses.
