1. DJB628's Avatar
    I finally got the phone, and just noticed it does not have an LED light when charging, looks like that option can only be attained if rooted ??
    03-22-2014 08:06 PM
  2. ansextra's Avatar
    With Active Display you really don't need an LED.
    03-22-2014 08:42 PM
  3. DJB628's Avatar
    Which means what, if screen is off, how do you know it is charging ?? I just got the phone so excuse the ignorance.
    03-22-2014 09:21 PM
  4. ansextra's Avatar
    My apologies. I rarely look at my phone when it is charging as I only charge before going to bed for the most part. I have found that if I turn the lock screen on, however, that it does say "charging" when plugged in. You are correct that the only way to have an LED light show when charging is by rooting the phone. Quite honestly, I would need more reason than a charging light to root the phone though... I do agree with you, though, that there should be some sort of indicator. It just never bothered me before. Good luck!
    03-22-2014 09:33 PM
  5. Rocketsaucev2's Avatar
    You don't know it's charging while it's plugged in? 😕
    Eclipsed Moto X
    mtndewgood likes this.
    03-22-2014 09:46 PM
  6. DJB628's Avatar
    Well you assume it is charging, but there is no LED indicator telling you it is charged, nor is there one telling you the phone is fully charged without unlocking the phone and checking. maybe I am spoiled with HTC and Samsung, just thought it was a basic thing, no biggie, i will deal with it.
    03-22-2014 11:15 PM
  7. Illustrator Joe's Avatar
    I get where you are coming from. Maybe there is some sort of app that gives you a notification when done charging???
    ಠ益ಠ
    03-23-2014 12:37 AM
  8. ScottMGS's Avatar
    You're right. There is no LED charging indicator. Coming from Samsung it took some getting used to. In fact, there is a green LED under the earpiece but without root you'll likely never see it - which is good since if it comes on it means your battery is very nearly dead.
    DJB628 likes this.
    03-24-2014 11:47 AM
  9. JoeNM84's Avatar
    I didn't even know other phones had LED lights to show when charging. Always been used to hitting the power button to check the lock screen, even on dumb phones years ago I don't recall a charging light on anything I had. Could just be I'm forgetting though.
    03-24-2014 03:46 PM
  10. droidslc's Avatar
    I got used to the light on the One, bugs me not to have it. Mostly because I've got a cord that has to sit just right, and sometimes the cable buried in my car's center console comes out and I don't notice it not charging.
    03-26-2014 12:42 AM
  11. mtndewgood's Avatar
    You could use llama or Tasker to play a sound or something when its fully charged. Llama is free but Tasker is not. Tasker is also more advanced. Give Llama a try. You can do a lot of cool stuff with it. It automatically turns my phone to silent at work. That's a big plus.
    Sent from my XT1056 using AC Forums mobile app
    03-28-2014 03:42 PM
  12. DJB628's Avatar
    Tasker is for rooted devices ??, I'm not rooted, as for Liama that is mainly a profiler, have you tried it, I don't think I want my phone beeping the whole time it is in the charger.
    03-29-2014 06:52 AM
  13. mtndewgood's Avatar
    I use llama. Ive tried both. Tasker does not require root.
    DJB628 likes this.
    03-29-2014 05:39 PM
  14. Puzzlegal's Avatar
    Both llama and tasker can be used unrooted, and can do more with root. Tasker is more powerful, but llama is a lot easier to learn to use. I have both, and use llama.
    03-30-2014 02:18 AM
  15. Khai Tran1's Avatar
    So does all moto g phones not have a led charging light? is that clear?! I tried calling but I think the lady did not completely understand. Someone please answer with yes moto g doesnt not have a charging light or yes it does have a charging light
    07-15-2014 05:25 PM
  16. hisense's Avatar
    Just wanted to add that the Moto X led will only turn on during charging specifically if the phone battery is depleted down to bare bones which is on the rare side. In this case it will switch on.
    11-08-2014 04:00 PM
  1. Galaxy S3 No service but data works
    By b799 in forum Samsung Galaxy S3
    Last Post: 05-13-2014, 11:37 AM
  2. Galaxy S3: No service but data works
    By b799 in forum T-Mobile Galaxy S III
    Last Post: 03-26-2014, 02:02 PM
  3. Htc one no OS
    By raj patel7 in forum Android 4.4 KitKat
    Last Post: 03-23-2014, 02:51 PM
  4. Frozen at Boot Screen, No Power Button. Please help!
    By jpkmiec in forum Samsung Galaxy S II
    Last Post: 03-22-2014, 06:55 PM
