Results 1 to 9 of 9
    teslapod's Avatar
    Posts
    Global Posts
    22 Global Posts
    Default Active Notifications - I'd like to be able to customize them - color, blink speed, etc
    I realize this would probably increase battery usage but I'd like to be able to change color and blink speed of active notifications depending upon the type of notification, contact information, etc. Kind of like the "light flow " app but using the active notifications.
  2. #2
    Default Re: Active Notifications - I'd like to be able to customize them - color, blink speed, etc
    check out -
  3. #3
    JungleLarry's Avatar
    Posts
    Global Posts
    700 Global Posts
    ROM
    MIUI
    Quote Originally Posted by teslapod View Post
    You're not alone. I don't have a problem with the current Active Notifications app (other than being able to dismiss notifications without unlocking the phone), but customization would be nice. Luckily, it seems like Motorola is keen on updating the feature through Google Play instead of system OTA updates. That's good news, so hopefully they address these concerns soon.
  4. #4
    Quote Originally Posted by Gekko View Post
    check out -
    Does this work with the X?
    Sent from my XT1058 using Tapatalk
  5. #5
    kjhee43's Avatar
    Posts
    Global Posts
    60 Global Posts
    Quote Originally Posted by JungleLarry View Post
    Not sure if this is what you are saying but you can dismiss them without unlocking. Well, dismiss from AN, not completely. Swipe to the right.
    I wish they'd flow suit and move active notifications to the play store and start enhancing the functionality of them.
  6. #6
    Posts
    Global Posts
    700 Global Posts
    ROM
    MIUI
    Quote Originally Posted by kjhee43 View Post
    I want to dismiss them completely so I don't see them hanging around in my notification bar. It's not that big of a deal, it just seems redundant.
  7. #7
    I'd like music controls or something. That and being able to better dismiss messages. Granted, I always look at the message anyway. I'd also like to be able to look at older notifications. Not sure if it currently dies this as I've only had the phone for a day, but from what I read it only shows you a preview of the most recent notification, and there is no way to launch into an older one directly. Correct me if I'm wrong n that.
  8. #8
    lordnikonz's Avatar
    Posts
    Global Posts
    5 Global Posts
    I completely agree. I think I might miss my led notifications. I loved being able to look across the room and see what notifications I had by the color. I would also like options to set how often the active display screen displays.
  9. #9
    Default
    Quote Originally Posted by lordnikonz View Post
    I can count on one time my phone has been on the other side of any room haha. Its in my hand or my pocket.
    On topic though.. OP should take this to G+ and tag Mark Rose. Moto is always taking feedback from users in the Moto X community.
  1. Replies: 2
    Last Post: 12-09-2013, 07:47 AM
  2. how to get back to stock with root?
    By corance in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 12-04-2013, 06:06 PM
  3. Safe to update N4?
    By dazed_android in forum Android 4.4 KitKat
    Last Post: 11-24-2013, 12:10 AM
  4. Reset changed the language to Chinese
    By jehu01 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 11-23-2013, 11:08 AM
  5. Any free app/tool to tweak permissions in pre-4.3 environments?
    By Continuum88 in forum General Help and How To
    Last Post: 11-23-2013, 11:07 AM
B
