I enable it in the battery screen, click refresh, and its back to off.
Tried a reboot and hasn't helped. Anyone else have this problem?
Here ya go :Not to hijack the thread but what does this feature do? I turned it on in the settings; and it stays on. But I haven't been able to find any info on what it actually does. Anyone know?
Hi I just researched this problem last night. If you're like me you've disabled as many apps as you can. In the process you have disabled moto assist. Battery saver for whatever reason relies on it. Just enable moto assist go to the app store and update it and battery saver will work.
I agree that battery saver won't stay on
I have Moto Assist on and the Battery Saver still won't stay onturn on moto assist app, may be you have disabled it. after turning this app on you will be able to turn on battery saver.
The tap to turn it on does turn it on but doesn't show. So when it shows off, tap it, then go back a screen and then back into battery stats and it'll be enabled.
