Results 1 to 7 of 7
    Default Ring volume low after coming out of vibrate
    Let's say my ring volume is at 80%. When I hold the power button to put the phone into vibrate mode, then later turning the ring back on via the same way, my ring volume will be set much lower at 25% or so. Anyone have this issue?
  2. Thread Author  Thread Author    #2
    Default Re: Ring volume low after coming out of vibrate
    Oh yeah I know, but I thought it would retain the previously set ring volume after coming out of vibrate-only mode. That was the case with my Motorola Atrix.
  3. #3
    How are you putting in vibrate? Chris
    Sent from my XT1060 using AC Forums mobile app
    I hold the power button and then press the vibrate-only icon.
  5. #5
    pgoelz's Avatar
    Posts
    Global Posts
    76 Global Posts
    FWIW, I just checked on mine (KK 4.4). I used the method you describe..... hold the power button to get the menu and select VIBRATE, then hold the power button and select RING. Mine retains the previous ring volume (about 75% in my case).
    Paul
    I just rechecked too. It retained the volume. There's another scenario I need to check, involving Assist meeting & sleeping. I'll report back.
  7. #7
    No problem here either and running 4.4.
    Posted via Android Central App on my Moto X
  1. Nexus 7: what is the percentage of your battery power after a day's use?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-16-2014, 07:59 AM
  2. thinking of getting lg g pad since there are so many glitches
    By Robin Hebert in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-24-2013, 07:29 PM
  3. samsung galaxy grand heating problem after the update
    By Ankit Bhatnagar 1318 in forum Samsung Galaxy Grand
    Last Post: 12-23-2013, 01:42 AM
  4. 'Profile Scheduler' together with 'Volume Locker'
    By Erhy in forum Android Applications
    Last Post: 12-23-2013, 01:14 AM
  5. Jellybean mic black out is back
    By Ancel Demonica in forum General News & Discussion
    Last Post: 12-22-2013, 09:55 PM
B
