Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree5Likes
    Default Moto X: Signal problems where my Galaxy Nexus had none
    My Moto X loses signal at certain indoor places (using the same sim card) where my Galaxy Nexus had no problems like my mom's house and a salsa place I go to. What gives? I thought Motorola is supposed to have good radios.
  2. #2
    Default Re: Signal problems where my Galaxy Nexus had none
    Quote Originally Posted by shinydiscopants View Post
    thats hard to believe because Gnexus has literally the worst radio ever in any smartphone.
    you are right that Moto X radio is the best out there a the moment.. I would say it might be some bug or maybe faulty radio...
    first, do a factory reset and then if that didnt fix call motorola.
    btw, I get amazing reception where my N4 previously failed
    Fancy A Break From Your iPhone? Have an Android Kit Kat
    jephanie likes this.
    I hear that a lot about the GNex, but I've never really had signal issues with mine except when when I go snowboarding at Lake Tahoe. I'm on T-Mobile and I think only Verizon gets decent coverage up there.
  4. #4
    Possibly it's the sim card? Did you put your Nexus sim card into the Moto X?
    Moto X (Ebony wood back, silver accents, black front)
    Previously: Samsung Galaxy Nexus - Droid X - Blackberry Tour 9630 - Dumbphones
    Yes. it's the same sim. I used a sim cutter. Would that matter? I could try having T-Mobile move the number to the new nano sim, I guess.
  6. #6
    I'd try getting a replacement SIM and doing a factory reset. I'm on Verizon so my story may be different, but my Moto X blows my Galaxy Nexus out of the water when it comes to reception. I'm getting a strong 4G signal in places where previously I couldn't even get texts to send.
    Current Device: Moto X VZW
    Previous: Galaxy Nexus, HTC Thunderbolt, Motorola Droid
    Before Android: Palm Pre, Blackberry Curve, Blackberry Pearl, iPhone (Original), Sidekick XL
  7. #7
    If you cut down a SIM card, I would definitely get a new SIM since you may have damaged the SIM When cutting it down.
  8. #8
    Definitely get a new sim. Moto x has excellent radios, something a lot of phones are lacking.
  9. #9
    All Moto X's come with a SIM already, right? He said he used his old one instead, so he could just use the new one that came with the Moto X to begin with and have it activated.
  10. #10
    Maybe I am just stupid, but how does a factory reset affect signal? If something is wrong with the radio, how will this change the outcome? I ask because my current signal seems worse than with other phones (-150 dBm) in a good size metropolitan city.
  11. #11
    Quote Originally Posted by reversalagent View Post
    In theory it shouldn't unless you are rooted and flashed different firmware. But it never hurts to restore to factory settings if you are having a problem and then to reinstall apps 1 by 1. Except for the time it takes to do it, of course.
  12. #12
    Thanks, I figured for flashing firmwares and such, but not sure how it would affect stock. I just can't figure out if the phone has a bad signal or this is just standard for my area. I need to pull out my older android phone (HTC Rezound) and see what happens.
  13. #13
    Golfdriver97's Avatar
    Posts
    Global Posts
    14,002 Global Posts
    ROM
    Stock Moto X
    Even stock ROMs can have a cached data conflict that can disrupt the software for the radios that a factory reset may clear up. However, in the OP's case, it is more likely the cut SIM card.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    Thanked by:
  14. #14
    I just want to apologize. I have not been having great signal with my moto x on verizon and just did a factory reset and it appears the mobile strength is now green, except when I am in the dungeon at work. It appears my signal strength greatly improved from doing a factory reset, but time will tell.
    Golfdriver97 likes this.
  15. #15
    Quote Originally Posted by Golfdriver97 View Post
    Posts
    Global Posts
    9,134 Global Posts
    ROM
    Stock Moto X
    DayThyme likes this.
  16. #16
    I get an awesome signal with my Moto X, even at work, where very few people get a decent signal. I get a decent signal inside the elevator too, which is crazy.
  17. #17
    Posts
    Global Posts
    14,002 Global Posts
    ROM
    Stock Moto X
    Has the signal improved?
    From a Sprint Moto X using AC Forums app
  18. #18
    Hard to say due to where I currently am at work, but leaving soon and will be in a different environment. But, when I stepped outside after the reset, the signal numbers were better (~ -110 dBm) and the mobile indicator in the battery area was green, more so than usual.
  19. #19
    GolfDriver or anyone who can explain: when one looks at the battery screen and sees the mobile strength indicator in various colors (red, green, yellowish-orange) how exactly is that broken down? Does green mean a good signal within a certain range or just a good connection, etc?
  20. #20
    Posts
    Global Posts
    14,002 Global Posts
    ROM
    Stock Moto X
    I think it is a range of the dBm. What the values are, I do not know.
    However, I do know that -60 is about as perfect as it gets, and -120 is crap.
  21. #21
    Before the reset, the Moto X was around -150 dBm and after the reset is around -120 to -90 dBm. Hence I can't tell for sure if this is normal or a radio issue. As I was driving home and talking, I looked back and it was green. While outside later, it was back to orangish again. I might have to pull out the Rezound and see if it was similar, even though I know they are completely different radios, manufacturers, etc.
  22. #22
    Posts
    Global Posts
    14,002 Global Posts
    ROM
    Stock Moto X
    What carrier are you on?
  23. #23
    Verizon, in the Memphis area. Hence this thread I started, but no one replied
    Verizon Moto X in Memphis Area - Signal Related
  24. #24
    Posts
    Global Posts
    14,002 Global Posts
    ROM
    Stock Moto X
    Gave a legitimate bump to your thread.
  25. #25
    Posts
    Global Posts
    14,002 Global Posts
    ROM
    Stock Moto X
    Check out Sensorly .com, and see how your coverage is. If it seems good, I would talk to Verizon about an exchange. The X really is a great device.
  1. help with mail problems on my samsung galaxy note 3
    By hoffer1 in forum Samsung Galaxy Note 3
    Last Post: 04-22-2014, 07:58 AM
  2. Replies: 50
    Last Post: 01-14-2014, 07:45 PM
  3. Active Notifications Problem
    By SandmanATHF in forum Moto X
    Last Post: 01-02-2014, 10:16 PM
  4. Replies: 5
    Last Post: 01-01-2014, 11:48 PM
  5. Several Galaxy S4 Problems
    By Stuart Campbell in forum Samsung Galaxy S4
    Last Post: 01-01-2014, 03:27 PM
B
