gabbott
Trusted Member
Re: Idle battery drain
Do you have the chromecast app installed by chance?
Location Reporting is different from simply having an app have access to your Location Services. Location Reporting will periodically report your location back to Google, where it's stored and used for things like Google Offers and sharing your location with friends in Google+. Google is somewhat vague in describing how it's used on their support page, but I know for sure it isn't necessary for apps to know where you are.
https://support.google.com/gmm/answer/3118687?hl=en
- - - Updated - - -
Nope. Should I avoid it?
Just a thought...maybe you have too many sync's going on. I found a bunch of apps that were syncing with Google that I didn't know about and didn't need syncing.
Go to Settings>Accounts>Google>tap your google account. That should show you a list of things sync'd with Google. App data, calendar, etc..Uncheck the ones you don't use or wish to have Google sync. I had a bunch I didn't need so ended up with Gmail, Google+ and Apps data. All the rest I un-checked. Good luck!
I think App Data sync is for backing up various app data to your Google account, as designated in the Settings/Backup & Restore menu.
People Details is likely all of the information for your Contacts--I'd keep that synced.
I keep the Facebook app set to manual refresh. It's easy enough for me to swipe down to refresh, and it will always refresh once automatically upon opening the app.
It just dawned on me, but why in the world would I need Facebook to automatically refresh when I'm not using it?? This seems kinda silly. I changed it to refresh "never". That's an easy one there! Especially considering, like you said, the app refreshes once you open it!
So, I've been running GSam Battery app since yesterday evening. Gave it until this morning to gather some data. Went into "view kernel wakelocks" and alarm_rtc is showing at the top of the list. Does this mean anything, or is this a normal reading?
That's a good thing. That means that the phone is only using up the battery when the screen is on. The OS and Google services aren't keeping the phone awakeStill can't figure out what is going on. I have location reporting off, and I haven't even installed Facebook. In fact, the only app I have installed so far is a weather app.
At first it was saying Android OS was using the most battery. I did a reboot and now it keeps showing that the screen is using 60%, and everything else is very low percentages. My phone is mostly idle. Any ideas?
Hey, just wondering did you figure out a fix? I have had my phone for about a month and a half and the battery life is terrible. I've tried it twice where I check the phone after 8 hours of sleep and I always lose 30% if the phone isn't plugged in. Do you guys think that it could be a faulty battery? My phone never lasts longer than max 13 or 14 hours and it constantly drains. I always close an app after I use it too so I don't get why its bad.
