Battery Drain from OS?
Sierra Kavanagh
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-frc3/q71/s720x720/1511032_10202161152849109_695905024_n.jpgSo, literally yesterday I updated my phone, and it can't be off the charger for 2 hours without draining to 30-40% without any sort of use. If I have the screen locked, it's draining it.
Is a screenshot I took of it, and like I said it won't stop draining. My running applications are also telling me that ALL my Google based apps are constantly running? I've uninstalled numerous apps to see if it would help, but it hasn't. Nothing seems to be helping. It was fine before the update?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
https://fbcdn-sphotos-g-a.akamaihd....720/1511032_10202161152849109_695905024_n.jpgSo, literally yesterday I updated my phone, and it can't be off the charger for 2 hours without draining to 30-40% without any sort of use. If I have the screen locked, it's draining it.
You have the Moto X, correct?
effreyj
710
3
Try turning off location reporting and make sure that the apps you have installed aren't requesting location.
WillyC
