Results 1 to 5 of 5
    Question Bluetooth audio quality issues
    I just received a new Moto X (ATT), and I've noticed some static issues with audio when connected through bluetooth in my car (Acura TSX 2009). I mostly use Pandora, but tested it just streaming Youtube and noticed the same issue. It doesn't seem to drop, but I am getting consistent, light yet annoying, audio static/pops every few seconds. I did not have this issue in this vehicle with my old Galaxy S2. Is this something that is related to the phone or the Android version (4.4.2). Should I bother trying to get a replacement? Did a search and saw some complaints about BT dropping, but I haven't noticed that as of yet. Thanks for any input.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    17,450 Global Posts
    ROM
    Liquidsmooth ROM
    Default Re: Bluetooth audio quality issues
    Quote Originally Posted by sje2081 View Post
    Welcome to the forums.
    It is probably the bluetooth radio. Can you plug the X into your sound system with a wire?
    Phone Timeline
    'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    Meaning the BT radio is bad in the unit?
    I need to find an AUX cable to try....car has USB but I get an unsupported error when I try to use it.
    Thank you.
    For what it's worth if anyone does a search on a similar issue and finds this thread...
    I fixed it by purchasing a Kinivo BTC450 and syncing to that in my car...audio is perfect. Strange since my car's BT works fine with my old GS2 and my wife's GS4, but sounded like garbage with my Moto. But the Moto must be "working" since it works on this BTC450. Also, even on my car BT, voice calls were OK, only music audio was poor. I just have to chalk it up to some incompatibility issue between the Moto and my Acura's BT. Maybe it'll get fixed in a future update.
  5. #5
    cordoni's Avatar
    Posts
    ROM
    Stock
    Had same issue in my challenger. Ended up balancing speakers 3 ticks to tear on radio and problem went away.
    "Give it time. You will be assimilated, resistance is futile. You are only here to serve the green R2D2. posted by HKM"
    If someone helps you find an answer, please Thank them with the button in their post.
  1. Bluetooth KeepAlive (to solve keyboard problem)... Has anyone used it?
    By SpookDroid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 05-04-2014, 06:09 PM
  2. Samsung Galaxy S4 Battery Issue
    By rond997 in forum T-Mobile Samsung Galaxy S4
    Last Post: 04-05-2014, 06:31 PM
  3. AT&T Note3 Gmail sync issue
    By OzarkArkie in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-02-2014, 01:08 AM
  4. kit kat issue?? or just galaxy note 3 issue HEEELLP
    By bethetruth in forum Sprint Samsung Galaxy Note 3
    Last Post: 04-02-2014, 12:11 AM
  5. Note 3 sync issues with music library
    By d_inalexus in forum General Help and How To
    Last Post: 04-01-2014, 10:48 PM
