DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 6 of 6
    notcalvin's Avatar
    Posts
    Global Posts
    165 Global Posts
    Default Soft Reset after lock up?
    I was wondering if anyone knows of a way, after the phone has locked up, to do a reset that does not require opening up the back and pulling the battery.
    My previous phone you could hold down power and toggle the mute switch 3 or 4 times and the phone rebooted.
    I'm hoping a trick like that is available for Admiral...
  2. #2
    zhecht's Avatar
    Posts
    Global Posts
    87 Global Posts
    Default Re: Soft Reset after lock up?
    On other Motorola android phones you can press and hold the Volume Down and Power buttons for about 10 seconds. I imagine that it is the same on the Admiral, although pulling the battery is probably just as easy.
    Thanked by:
    notcalvin's Avatar
    Posts
    Global Posts
    165 Global Posts
    I meant to reply earlier, but this didn't seem to work for me, even when the phone was not locked up.
    thanks for replying though, much appreciated.
    Chuck
  4. #4
    I guess I shouldn't jinx it, but I've yet to have my Admiral freeze to the point of needing a battery pull. I could see how that would be a PITA though, that back certainly isn't the easiest to get off.
    Always have your stuff when you need it with Dropbox. Sign up for free! http://db.tt/4AiUNSMC
    Mine
    - Sprint Samsung Galaxy Nexus 4G (Jellybean 4.2.2)
    Wife's - Sprint LG Viper 4G LTE (ICS) and Vizio VTAB1008 Tablet (Honeycomb)
    Daughters' - Nabi2 tablets (ICS)
    Never trust a computer (or phone) named after a fruit.
  5. #5
    Default
    Quote Originally Posted by ahecht View Post
    I figured this would work, too, but it didn't. I haven't found a reset button to keep me form pulling the battery.
    Best regards,
    -boggsie
    Sent from my Motorola Admiral on Sprint using Tapatalk
  6. #6
    hold vol+ , vol - , camera and power all four at the same time
