Results 1 to 2 of 2
    Default [ROM] [Leak] Gingerbread 2.3.4 Firmware 2.0.84 (8/19/11)
    This project was done by Eccentric Vision Development Team, which consists of myself and tatted. It is Android 2.3.4 with the new Blur. At this point, no root is achieved. That is still being worked on.
    This will definitely void your warranty. We are not
    responsible for bricked devices, out of warranty fees, broken
    relationships, nuclear war, or anything. By doing anything in
    this thread, you do so at your own risk and know the potential
    risk of doing so. If you are not comfortable with SBF, stock
    recovery, etc, do not attempt. You have been warned.
    To install this, you need to be on a completely stock 1.1.30 firmware with all the bloatware still intact. It works best without having Slightly Blurry installed, as that rom is deodexed and this Leak is not. You WILL encounter force closes if you do not use a stock 1.1.30 release.
    multiupload.com/DY51JVLSTF
    Copy update.zip to root of your sd card.
    To install, enter stock recovery by holding down X and Power until you see the Android and Exclamation Point. Close the keyboard and press the Volume Up, Volume Down, and Camera Keys (use volume keys to navigate and power button to select). Scroll to Wipe Data/Factory Reset and press Power. Scroll to Wipe Cache and Select Power. Scroll to Apply update.zip and press power. This will install GingerBread.
  2. #2
    Default Re: [ROM] [Leak] Gingerbread 2.3.4 Firmware 2.0.84 (8/19/11)
    link is gone repost please
