Results 1 to 17 of 17
    MacHouse83's Avatar
    Posts
    ROM
    4.0.3 ICS Leak
    Thumbs up Droid 2 extended battery
    Since I got my Droid 2 Global 2 weeks ago I've been tested out the extended battery I also purchased from Verizon. What can I say but damn good battery... it goes 20 hours easily with heavy use and 25+ with moderate. If you have a OG Droid, Droid 2 or D2G make this purchase for yourself pronto!!!
    Pure Google.. Nexus
    Thanked by:
  2. #2
    Default
    Would you mind posting a photo or two of your D2G with the extended battery installed? I was looking at them online but the stock photos of the battery make it look like it adds a lot of bulk to the handset. I was just curious how it actually looks/feels in reality..
    MacHouse83's Avatar
    Posts
    ROM
    4.0.3 ICS Leak
    Default
    I attached a picture from the web with a Droid 2 w/extended and without... the weight i honestly dont notice any difference and in person youll barely notice it
    Attached Thumbnails Attached Thumbnails Droid 2 extended battery-2010-08-25_01143_dsc_0028.jpg
    Pure Google.. Nexus
    Thanked by:
  4. #4
    Default
    Quote Originally Posted by MacHouse83 View Post
    Nice. Is that the 1860 mAh battery, then? I was looking at the 2800 mAh one that Seidio sells and it is HUGE:
    Amazon.com: Seidio Innocell 2800 mAh Battery for Motorola Droid with Replacement Door (Black): Cell Phones & Accessories
  5. #5
    Default
    Here is my story: I got mine a few weeks ago from Motorola, but they didn't give me the door.
    I then ended up paying about $14 total to get the door.
    It shows up finally on Friday and the legs are a bit bent.....I try to put them in place and finally it fits and slides in place. Only thing is that I tried to fit it on with out the battery in, and now the dang thing wont come of! The Battery door is stuck on my phone and with no battery inside I have essentially turned my phone in to a brick! Motorola is closed for the weekend too....
    I took to a Verizon Store Saturday morning and they were able to get the door off for me....at least I have a working phone now. Motorola said they will send out a new battery door and ensure it is not damaged in transit this time and not to worry about sending the damaged one back.
    So my question is, how much did you pay VZW for the batter and door? Also does the door slide on and off as easily as the standard battery door? Is there any tricks to it? The VZW guy said he has seen a lot of problems with the extended battery doors......
    MacHouse83's Avatar
    Posts
    ROM
    4.0.3 ICS Leak
    Default
    @phantasmah yes its the BP7X 1860 mAh battery which should be perfect for you if your looking into getting a extended battery.
    @blaisedinsd I got the battery and door from Verizon for like $50 which to me is a good deal. Its actually a package, only thing is if you have a Droid 1 the doors that come with the battery is only blue so far that matches with the Droid 2. Honestly it is a little tough to ge tthe door off but its managable, I rather have a really secure door cover than a loose one though lol.
    Pure Google.. Nexus
  7. #7
    danpeake's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default
    Do you know if the extended battery (and door) fits in the Motorola car dock? That would be a deal breaker for me. Thanks.
  8. #8
    Default
    I got the Moto extended battery w/o a door. I had read that some people are using the phone with only the back of a Seidio Innocase and thus that is what I have been doing. Works just fine. Fits into the MM charger. And the battery temp is running in the 80's.
    MacHouse83's Avatar
    Posts
    ROM
    4.0.3 ICS Leak
    Default
    @danpeake i dont know for sure if it does or not, but the verizon clerk said it should fit the car and desk dock without any problems.
    @ishore i guess if it works it works lol
    Pure Google.. Nexus
  10. #10
    Default
    I have the extended battery on my D2G and it fits in the multimedia dock with no problems. Do not have the car dock so can't say for sure.
  11. #11
    x1sspic's Avatar
    Posts
    Global Posts
    42 Global Posts
    Default
    Quote Originally Posted by bsmith151 View Post
    It does fit in the car dock as well.
    Scott
  12. Thread Author  Thread Author    #12
    MacHouse83's Avatar
    Posts
    ROM
    4.0.3 ICS Leak
    Default
    niceee, i will be looking into getting a desk dock then!
    Pure Google.. Nexus
  13. #13
    Default
    Is thers a case that fits the G2 with the extended battery...thanks
  14. #14
    Default
    thanks for all the info
  15. #15
    Default
    what cases can fit the phone with the extended battery?
  16. #16
    Default
    Wow, that is slim for an extended battery. I use two regular batteries on a daily basis because I despise large extended batteries, but this looks like one I just might have to buy :0
  17. Thread Author  Thread Author    #17
    MacHouse83's Avatar
    Posts
    ROM
    4.0.3 ICS Leak
    Default
    I think the regular Droid 2 case can fit with the extended battery, maybe a little snug but it should fit ok!
    Pure Google.. Nexus
