Results 1 to 11 of 11
- 01-21-2011, 04:10 PM
Thread Author #1
- 01-21-2011, 04:19 PM #2
What's the error message?
- 01-21-2011, 04:22 PM
Thread Author #3
- 01-21-2011, 05:23 PM #4
Is this happening with every Wi-Fi network, even open ones? I had an issue with my Wi-Fi when traveling because as it turned out when I set my home Wi-Fi up, which I have set to static IP, it then wouldn't grab an IP until I turned dynamic IP back on in the phone. It doesn't use separate profiles for static and dynamic for some odd reason so it had to be set to what I was connecting to.
Rev.Galaxy S3
Ubuntu Linux 10.04
IT Tech - 01-21-2011, 05:28 PM
Thread Author #5
- 01-21-2011, 08:27 PM #6
If its your home network you might want to try using Wep. When I first set up my phones wifi I used a Wpa secured connection and would get error messages like that. It would connect on and off and then I would eventually get the network error. Switched the router to a Wep connection and now I have no problems.
- 01-22-2011, 10:10 AM #7
- 01-24-2011, 12:54 AM #8there is no spoon
- 01-29-2011, 07:18 PM
Thread Author #9
- 02-03-2011, 09:43 AM #10
I have had the issue too when trying to get e-mail via wifi. I just got fed up with it and turned off wireless since I get decent signal in my home.
It seems that Wifi and 3G are fighting when an app is trying to access the internet.
I am using WEP on my router. - 02-04-2011, 02:15 PM #11
I was trying to connect to the open Wi-Fi at the hospital several weeks back....It was a dead zone for cell service....my Droid 2 connected with no problems but my wife's droid 2 would not. I couldn't figure out why.
Reply
