Results 1 to 10 of 10
- 01-29-2011, 05:47 PM
Thread Author #1
Problems Flashing Droid 2 with SBF
My phone was stuck on the bootup motorola icon. I could get into stock recovery and bootloader. Read many posts about using RSD Lite to flash a stock SBF file to my phone. I followed the instructions to the letter but every time it fails at switching phone to bp pass through mode.
Now whenever I boot it only goes to the bootloader:
"Bootloader
D2.37
Code Corrupt
Battery OK
OK to Program
Connect USB
Data Cable"
I heard that there was a way to flash the phone with SBF inside of Linux instead. I was wondering if my problems might simply be driver related and if this might fix it? Also what is the process to flash a SBF file from Linux?
Thanks alot. - 01-30-2011, 08:23 PM #2
make sure you have the latest SBF i believe it is v2.3.20
Update: sorry 2.3.340 is whats currently on the X.Last edited by corydunbar; 02-08-2011 at 02:10 PM.
Blackberry Storm 9530 (1 year)>
Motorola Droid [Rooted] (Froyo 2.2 --> 1Ghz ultra low voltage) (8 months)>
Motorola Droid X [Rooted] (Fission v2.6.1 --> 1Ghz--> low voltage)(10 months)>
HTC Droid Eris [Rooted] (CM 7) (risky outdoors device)(current)>
HTC Droid Incredible [Rooted] (CM 7)[Bad ESN <craigslist scam>](just a tablet now)>
Motorola Droid 2 [Rooted] (GingerBread v2.3.3 Blur v4.5.153 --> 1Ghz) (Current)
[/FONT]
Next device: Samsung Galaxy S II - 02-01-2011, 01:06 PM
Thread Author #3
So I used a ubuntu live cd and flashed my phone from the terminal it seemed to complete and the phone rebooted. It then loaded up the Motorola boot logo and I thought this nightmare was finally over, but unfortunately after about 3 seconds or so it goes from the Motorola logo straight into the Bootloader. Only now the "Code Corrupt" message is no longer in the bootloader.
I can now boot into the stock recovery. Not sure why the SBF flash seems to have worked and not worked at the same time. Maybe now that I can get into recovery I can flash an update.zip to my phone?
Please help. - 02-02-2011, 11:36 AM #4
It sounds like you need to retry the SBF
[/FONT]
Next device: Samsung Galaxy S II - 02-04-2011, 02:19 PM #5
Will this work if your rooted and running something else?
I have been running the Motoblur leak Version.3.0.0.A955.Verizon.en.US and I guess I didn't properly do a backup before I did it.
I was wondering how to go back to stock if I need to....I have had some occasional issues with the screen not coming up and the phone not turning on.
I downloaded the SBF but haven't tried it....will it work? - 02-04-2011, 04:54 PM #6
Unfortunately, I think when you switched to the 3.0.0 ROM you upgraded what your e-fuse checks. So until Motorola leaks an SBF for the 3.0.0 you're out of luck. Don't hold me to it, but the TBH may be able to help you out.
sent from my Motorola DROID X / DROID 2Blackberry Storm 9530 (1 year)>
[/FONT]
Next device: Samsung Galaxy S II - 02-07-2011, 11:35 PM #7
I was able to use the SBF with no problems after 3.0
I use VRZ_A955_2.3.20_1FF_01.sbf
What is v2.3.340 ? Is that a VZW update? - 02-08-2011, 02:13 PM #8
sorry i mixed up my Droid 2 and Droid X updates. the 2.3.20 is the latest SBF for the Droid 2.
[/FONT]
Next device: Samsung Galaxy S II - 02-15-2011, 12:50 AM
Thread Author #9
- 02-15-2011, 02:52 PM #10
dont hold me to this
but i think that process should work. Your hardware is likely not at fault. So all you have to do is get official software booting up again.Blackberry Storm 9530 (1 year)>
[/FONT]
Next device: Samsung Galaxy S IIThanked by:
Reply
