Results 1 to 3 of 3
    thomashedd1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gingerblur (Stock w/root)
    Question Seidio Inocase has loose top left corner, shoud i return?
    I have the D2G and i just recently recieved in the mail after ordering from here the seidio case and the top left hand corner is really loose, whether im typing or even i just touch up there it moves and rattles. The droid 2 global has the camera hump, which most cases including this one dont account for, im wondering if i will have the same problem even if i return the case and get a new one of the same kind or if i just got a faulty one.
  2. #2
    John Yester's Avatar
    Posts
    Global Posts
    19,848 Global Posts
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default
    Pretty sure they are all like that. including my own. There is nothing for it to mount to...
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    ok, thanks
Tags for this Thread
