Results 1 to 7 of 7
    Default Battery Problems
    My battery has gotten so poor, I can barely make it through half a day without having to charge it. I can't seem to find the problem either. I was thinking that because I use a dock at night it may have degraded the quality of the battery faster, but I'm not sure. Anyone have the same problem or any suggestions?
  2. #2
    Default
    If you can, buy a new battery. Id go for the verizon extended battery. Its $50 but its very slim and hardly adds any thickness to the phone. My battery life is not the best, and this is the battery I plan on buying.
    Default
    I haven't had the phone all that long, I had the D1 before, and the battery lasted much longer than this one, even though I did eventually have to replace it
    Default
    And now it's taken to randomly not turning on the screen and then resetting itself. Any ideas what could be wrong here?
  5. #5
    circustravis's Avatar
    Posts
    Global Posts
    120 Global Posts
    ROM
    2.3
    Default
    Is it overheating? Mine will reboot when it gets too hot.
    Default
    Yes, it was. Oddly enough, I took my brightness of auto and lowered it, it seems like this may have fixed (or at least made a little better) the issue. Will report back soon.
    Default
    Well, that seemed to make it better for a few days, but now it seems to be back to its old fast drain. Still don't know what the problem is, and on top of that when I go into my battery manager it always immediately FCs. Any ideas?
