Results 1 to 6 of 6
- 07-13-2011, 04:12 PM
Thread Author #1
Icon next to battery
There is an icon to the right of the battery that looks like a vertical battery with a check mark in it. I've never had this on any other android devices. does anyone know what that is?
- 07-13-2011, 05:04 PM #2
Re: Icon next to battery
Was wondering myself
- 07-13-2011, 05:44 PM #3Thanked by:
- 07-13-2011, 05:48 PM
Thread Author #4
yeah thats exactly what it is
tested it by turning all my alarms off and it went away.
didn't think it looked at all like a clock. they might have wanted to design it going the opposite way so it doesn't look exactly like a check mark - 07-13-2011, 05:48 PM #5
You are right...I toggled my alarm and it went away then came back
- 07-13-2011, 05:59 PM #6
Reply
