1. Lsx346's Avatar
    anyone notice it when in a call?
    08-03-2011 01:23 AM
  2. Pain505's Avatar
    yeah, its to turn off the screen while on a call, so that you do not accidentally press any buttons.
    08-30-2011 02:31 AM
  3. myersjesse's Avatar
    It is used for "in-pocket detection". If you de-select In-pocket detection you should not have the red light. setting>display>In-pocket detection.
    With the two d3's that I have had the pocket detection seems to only work for a little bit until you re-boot the phone.
    08-30-2011 10:18 PM
