Results 1 to 5 of 5
    xxckwxx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default [Help]Droid3 On virgin mobile
    I have been searching for a answer, but... YET I haven't found a actual guide or instruction on getting a D3 onto Virgin mobile. Can I please have a hand with this? :S
  2. #2
    macten52's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [Help]Droid3 On virgin mobile
    The D3 won't ever go onto Virgin. Virgin uses Sprint's network which is CDMA like VZW but the D3 is locked to VZW. Now you "unlock" a D3 but that means the SIM card which may allow it to work on GSM networks in other parts of the world. Normally it won't work on any domestic GSM networks. so sorry a D3 isn't really usable for anything but VZW.
    xxckwxx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But.. my friend had a d3 on Virgin Mobile...? :o
    xxckwxx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can anyone else help? :O
  5. #5
    joey92's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is it possible to put a D3 on page plus or straight talk if so how would one go about doing it
    Sent from my XT862 using Android Central Forums
