1. UrbanTwitch's Avatar
    System version: 5.7.906.XT862.Verizon.en.US
    Model Number: DROID3
    Android Version: 2.3.4
    It's never been in washing machine or gotten wet. Aside from the few drops, it's been fine.
    The sound is completely dead. Nothing. It's at 100% full volume and still...
    Help?
    06-13-2013 11:51 AM
  2. doogald's Avatar
    Do you hear anything with headphones plugged in? Have you checked all of the volume settings at settings->sound->volume (particularly media volume)?
    Also, there is an app called Quick Settings that exposes more volume controls. Maybe some of those (like system volume) are set to 0?
    https://play.google.com/store/apps/d...guYmVxdWljayJd
    That's where I would start...
    06-14-2013 11:47 AM
  3. UrbanTwitch's Avatar
    Turns out... turning it off and on again solved the problem...
    06-14-2013 12:16 PM
  4. Kelly Roseberry's Avatar
    Help?
    04-30-2014 09:05 AM
  1. Replies: 2
    Last Post: 04-30-2013, 07:52 AM
  2. ICS update lost all my ringtones and notification sounds
    By still_smoking in forum Verizon HTC Rezound
    Last Post: 08-04-2012, 08:40 AM
  3. Lost all sound
    By Kromen in forum AT&T Captivate
    Last Post: 09-17-2011, 01:07 PM
  4. I am completely lost and i think i semi-bricked my phone help!!
    By spidergirl0408 in forum G2 Rooting, ROMs, and Hacks
    Last Post: 04-14-2011, 09:00 AM
  5. Lost all my phone numbers
    By hkrn44 in forum HTC Droid Eris
    Last Post: 05-04-2010, 07:42 PM
