Results 1 to 4 of 4
- 05-07-2012, 11:53 PM
Thread Author #1
My battery drains faster than I think it should.
Hey Everyone I just got the Motorola Droid 4 about two weeks ago. I have been using smart actions especially at school. It sets my brightness to 9% (not sure if lower or auto saves more battery) turns of gps and wi-fi and other batter drainers. I also switch to cdma only. And I hardly even use my phone during school but somehow after 6 hours Im down to 30. So im loosing 30% every 3ish hours.
Is this normal?
I also use a two battery savers one with display on, and one with display off with each its different actions. - 05-08-2012, 07:21 AM #2
Androids are notoriously bad with battery life. Carry a charger with you.
Tappin' and talkin' with Tapatalk.Rooted Droid 4 with Jelly Bean 4.1.2, system version 98.72.18.XT894.Verizon.en.US
- 05-08-2012, 08:42 AM
Thread Author #3
- 05-30-2012, 07:39 AM #4
Re: My battery drains faster than I think it should.
Pretty much:
- Turn off certain features when not in use (Bluetooth/GPS/WiFi)
- Lower brightness
- Make sure you close whatever apps you're not using properly
I think it's the same for any 4G phone.My Devices:
Motorola Droid RAZR MAXX
Apple iPad 3 (soon to be Nexus 7)
Reply
