Results 1 to 2 of 2
- 07-09-2012, 04:30 PM
Thread Author #1
- 07-09-2012, 10:20 PM #2
Re: Question about Smart Action -wifi connection.
I use Widgetsoid. It's in the Play Store and it's completely free. To me, it's one of the best apps to create widgets. It allows you to create rows of Widgets, and the amount of choices you get is awesome. You can also edit the colors of the widgets or make them transparent, which is what I do so that I still see my wallpaper
Reply
