Results 1 to 4 of 4
    Default Droid 4 Won't Charge, Stuck at 0%
    I bought a Droid 4 off of fleabay in the hopes of resuscitating it. The phone is in perfect condition and no water damage, but when I plug it in, the charging splash screen comes up and stays at 0%. I have made sure to use a motorola charger and cable, supplying the proper amperage and left it plugged in for 8 hours in case of deep discharge. The only thing I can get into from the power&volume-+ menu is fastboot, but it says the battery is too low to do anything.
    Do the Motorola factory cables work to power the Droid 4 in fastboot? Everything I have read says they don't work for the Droid 4. Does anyone have any other suggestions to bring this thing back to life? I'm wondering if the battery is just defective.
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default Re: Droid 4 Won't Charge, Stuck at 0%
    Quote Originally Posted by techtoaster View Post
    yeah i would start with trying to find someone that has the same phone or a motorola that uses the same battery if possible and try to use it , eliminate that as a cause then tak it from there
    If i've made life easier buy me a Macchiato
    I fixed it! I couldn't find any Google results for this particular problem so hopefully this helps someone. If your Motorola Droid 4 is not charging and stuck on the battery icon with zero percent displayed, a Motorola "factory" cable will likely fix it, if the battery isn't dead. I used this thread to make a factory cable:
    As soon as I plugged my frankenstein cable into my PC, the phone booted right up. I scored a Droid 4 in perfect condition for $50 on fleabay, and now it works! yay
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Awesome congrats
  1. Charge stuck at Samsung screen
    By paxil in forum Verizon Droid Charge
    Last Post: 09-30-2012, 03:09 PM
  2. Stuck at Droid Eye
    By Omni181 in forum Verizon Droid Incredible
    Last Post: 11-21-2011, 11:43 PM
  3. Droid (A855) won't power up - at all. Interesting case..
    By paintba11er89 in forum Motorola Droid
    Last Post: 10-28-2011, 10:46 AM
  4. Droid X won't charge battery
    By mawgspawn in forum Motorola Droid X
    Last Post: 08-14-2011, 07:18 PM
  5. droid incredible stuck at black screen
    By rodney01 in forum Verizon Droid Incredible
    Last Post: 10-31-2010, 01:23 AM
