Results 1 to 2 of 2
    Lefty Drummer's Avatar
    Posts
    Global Posts
    370 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    .246 ICS
    Default Easy fix to route phone call audio to 3.5mm jack when using vehicle dock
    Hi folks,
    Wife has a droid 4, just decided she wanted a car dock. So we ordered the oem version from Amazon. She absolutely loves it, however the phone is not routing phone call audio to the earpiece jack which is connected to car stereo via cassette adapter (don't laugh). She wants to hear incoming phone call audio through the car stereo speakers. Any how, wanted to see if there was a setting we were overlooking. My note 2 has such a setting to enable/disable audio to the phone's speakers. Any help would be appreciated, thanks!
    Sent from my SCH-I605 using AC Forums mobile app
  2. Thread Author  Thread Author    #2
    Posts
    Global Posts
    370 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    .246 ICS
    Default Re: Easy fix to route phone call audio to 3.5mm jack when using vehicle dock
    Okay... Talk about Duh!! My wife was not home when I posted originally so didn't get a chance to fully investigate until last night. Problem was not technical at all, the plug at the end of the wire coming from the cassette adapter would not fully seat in the earpiece jack when the phone was in the dock. The hole on the side of the dock is too small for that plug to completely connect into the jack. I got a spare 3.5 mm audio cable that had a small plug end that fit properly through the hole, and got a coupler to connect the two cables. Viola! Problem solved, all audio now comes out the car stereo speakers. Sorry to waste everyones time...
  1. Samsung Galaxy Ace won't connect to wifi
    By sneaky cat in forum Samsung Galaxy Ace
    Last Post: 11-01-2013, 04:54 PM
  2. Possible to wipe everything and start over?
    By Andrew Fazio1 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 09-23-2013, 08:35 AM
  3. How to revert to stock rom
    By brinith in forum General Help and How To
    Last Post: 09-22-2013, 05:27 PM
  4. Replies: 2
    Last Post: 09-22-2013, 10:56 AM
  5. How do you stop screen from coming on when you end a call???
    By 44pirate in forum Verizon Samsung Galaxy S4
    Last Post: 09-22-2013, 09:59 AM
