What all does battery saver affect?
russel5150
1,274
6
I have thought about using.. I actually used smart actions on my old razt maxx. But I'm not sure how much it cuts down performance.. Or what it shuts off.
Thanx
Sent from my XT1080 using AC Forums mobile app
Thanx
It can depend on the battery saver. Some cut performance from the beginning, like you suggested. Others engage when the battery reaches a certain level. Personally, I dislike them. I used to use the battery saver on my S3, and never noticed much of a saving, so I stopped.
On my note2 the battery saver seemed to actually make it worse lol.. I could get all day w it w pretty steady use..
Was just curious about this one.. I won't mess w it until I feel I need to
Samsung used to have their saver set up so that if you hit a certain level, it would automatically turn off things like GPS, WiFi, etc...
Sent from a SlimROM S3.
Great question. I was wondering about this myself and tried searching forums with no success. Event went to Motorola's site and didn't get anything there either.
If u click on battery saver under options it tells you that it doesn't do anything until the battery gets low. On some phones it underclocks the CPU. With this processor having different dedicated cores for things, that wouldn't really do anything. So it just lowers brightness and stops sync on asps when the battery gets low.
Battery saver for sure kicks on at 15% battery. You get a notification when that happens and your screen drops multiple levels of brightness.
McAllister81
