1. kurpaige's Avatar
    Anyone having problem with text ringtones? I don't get text tones or vibrates at all. Google Voice work but not text.
    08-25-2013 06:01 PM
  2. swany1970's Avatar
    I've noticed this as well. Not sure what's going on.
    Sent from my XT1080 using Tapatalk 4
    08-25-2013 09:43 PM
  3. nikoaudio1's Avatar
    I want to say I had this problem on day one, but playing around with the volume settings seemed to fix it. (No sarcasm)
    08-25-2013 09:47 PM
  4. Phenix's Avatar
    Double check all your volume levels. Remember that notification volumes aren't linked to the volume rocker so they might be turned down even when your ringer is turned up. Also try setting a new notification sound from within the messaging app settings.
    08-26-2013 04:32 AM
  5. kurpaige's Avatar
    DIdn't know that, will check as soon as I can get back to my phone. Hope that's all it is cause everything else seems to work fine.
    08-26-2013 09:21 AM
  6. swany1970's Avatar
    This works! Strange that this time they did that. I turn off all notification sounds. The only sounds I want are ring tones and SMS/MMS
    08-26-2013 09:35 AM
  1. Having problems rooting Samsung Conquer 4G
    By jetskid420 in forum Samsung Conquer 4G
    Last Post: 08-26-2013, 06:26 PM
  2. Screen problem
    By purefire231 in forum LG Optimus G Pro
    Last Post: 08-26-2013, 12:45 PM
  3. Anyone using Smart cover without the wake timeout problem ?
    By prowede in forum Google Nexus 7 (2013) Accessories
    Last Post: 08-26-2013, 11:17 AM
  4. Texting Issue
    By austriak in forum HTC One M7
    Last Post: 08-25-2013, 05:57 PM
  5. Having text issues with my RAZR MAXX from Alltel
    By terryh215 in forum Droid RAZR MAXX
    Last Post: 08-25-2013, 11:58 AM
