11-11-2013 03:33 PM
34 12
tools
  1. jeep_man's Avatar
    I have had my maxx for a week now. Bought the ghost 100 droid branded wireless charger but exchanged it for the Nokia dt100 at my local store due to the ghost being defective (would get too hot and stop charging ).
    I love wireless charging except for one thing...the wireless charging notification sound it makes every time I lay my phone down.
    I have been through every setting I can think of and still haven't found a way to disable this? My wife is going to kill me if I dont figure this out as I only charge my phone at night and it is constantly making noise every time I move the phone.
    Somebody HELP!!!!
    08-28-2013 03:42 PM
  2. 18t's Avatar
    you could always you know, use the stock charger
    i dont think there is a simple solution, i think you are going to have to sacrifice something. if your phone is on silent does it still chime when placed on the charger, or does it vibrate?
    here are my ideas without exactly knowing the end result, but i imagine your phone is going to have to be on silent.
    #1. put phone on silent. or have a tasker profile setup to go into silent mode at a specific time or when connected to home WiFi after specific time.
    #2. have an NFC sticker by your entryway and tap it as you are walking in the door. setup the NFC sticker to put phone into silent mode. (i dont know if you want your phone on silent, if you dont you can add a tasker profile to leave silent mode once it starts charging)
    #3. put phone in different location OR dont use wireless by the bed, use it at work.
    #4. return wireless charger and get the griffin powerdock for droid ultra/maxx.
    PS- how do you like the dt-900?
    viper81 likes this.
    08-28-2013 03:50 PM
  3. Pauljr's Avatar
    I have the Tylt Vu wireless charger and have my phone sent to silent during my night time sleep. I don't hear the phone at all when charging. Go to Settings/ Active Notifications/ then check Sleep at night and plug in your time period. It's an easy as that.
    DROID Maxx ~ Android Central App
    08-30-2013 07:38 AM
  4. JB007Rules's Avatar
    My wife is also ready to shoot me! Putting the phone into "sleep mode between this hour and that hour" does NOT WORK! I have the "DROID" wireless charging pad.
    The ONLY way is to put the phone to silent! Not happening! If my phone rings in the middle of the night I NEED to answer it! It's either an emergency or a sales call from someone over seas which I make money on!! All other alerts are set to vibrate only anyways (email, txt, calendar, etc etc...)
    HELP!! GAH!!!
    09-04-2013 11:54 AM
  5. McIrish's Avatar
    did you try something like Simple Sound Profile Widget? I set mine up to a new profile I made called "phone only" when I'm ready to sleep. The only sound is when the phone rings. I have all other sound settings to silent. maybe its different with wireless charging, but it works great for me.
    09-04-2013 03:29 PM
  6. joshzide's Avatar
    I have an imperfect, but decent solution.
    1. Using Llama, I set up the following:
    When Wi-Fi is connected to my home network AND time is between 9pm and 6am AND battery is in use AND screen is on, Do the following:
    - Change profile to Ringer off (profile I created which just shuts the ringer)
    - Queue event - Ringer back on when: (user is present OR screen is Off) AND above criteria are met
    - Queue event - Ringer back on (delay 15 seconds) AND above criteria are met.
    2. To use: push the power button, but don't unlock the phone. Put on wireless charger before the screen shuts off again.
    Seems to work fine, though I'd prefer to just be able to silence the stupid notification.
    09-04-2013 05:18 PM
  7. Busted51's Avatar
    its odd because when my sound is on I get 1 wireless charger beep and that's it! nothing more.. and when I'm on silent I get no beep
    Posted via The Maxx
    09-04-2013 06:50 PM
  8. joshzide's Avatar
    aue123- that's the same thing I get, but the charging sound (even the once) is loud enough to wake my wife. Silencing the ringer is not an option for everyone, and unfortunately, the wireless charging sound is linked to ringer volume rather than notification volume for some strange reason.
    09-04-2013 07:23 PM
  9. Busted51's Avatar
    curious if you use assist and make it think your in a meeting from whatever time.. the calls still come thru
    Posted via The Maxx
    09-04-2013 07:27 PM
  10. Cincybearcatfan's Avatar
    What if you deleted the charging sound or changed it to another sound named wireless charging sound that's quieter or less annoying?
    Sent from my Droid Maxx by Motorola using Tapatalk 4.
    09-04-2013 10:38 PM
  11. CrazyRussian007's Avatar
    You need root to delete the sound
    09-04-2013 10:46 PM
  12. Cincybearcatfan's Avatar
    Exactly. It's not like the annoying Droid sound at boot. You can delete or rename any sound once your phone is up.
    09-04-2013 10:51 PM
  13. Adriano Feria's Avatar
    That is quite the oversight from Motorola. This is something small, but it is quite annoying. I hope they add an option to the stock settings menu that allows users to change the sound.
    09-06-2013 09:27 AM
  14. rjack22's Avatar
    I sometimes get the sound and other times I do not. I wonder why this is?
    09-06-2013 10:11 AM
  15. joshzide's Avatar
    One thing I've noticed is that it only makes the sound if the battery is below some threshold charge. I haven't figured out if that threshold is 90% or 95%. Have you NOT heard the sound when the charge level was below that and the ringer wasn't silent?
    09-06-2013 12:08 PM
  16. JimBen73's Avatar
    Same here, the sound doesn't bother me though...
    Posted via my awesome, longer lasting phone than yours aka droid MAXX
    09-06-2013 12:57 PM
  17. rjack22's Avatar
    I will have to pay more attention as to the level of the battery when I put it on the charger. That probably is why.
    09-06-2013 04:11 PM
  18. Coldiguana's Avatar
    Why do all that? I used Llama to simply turn on a profile with sounds when it detects wireless charging. Before I wirelessly charge, I use the power swtich to turn off the ringer (simple operation, short push of power switch then choose far left, "silence" mode.) Then put the phone on the charger and the phone (Llama) will turn off silent mode and select your normal profile (or whatever profile with sound that you'd like).
    09-26-2013 05:32 PM
  19. Snareman's Avatar
    I've noticed that as well.
    10-02-2013 10:34 PM
  20. mgullick's Avatar
    Have you tried this?
    10-04-2013 03:20 PM
  21. KWKSLVR's Avatar
    Maybe exchange your wife for a newer model?
    10-05-2013 03:56 PM
  22. LabRat's Avatar
    The upgrade fee is often prohibitive.
    slim6596 and KWKSLVR like this.
    10-06-2013 01:49 PM
  23. mgullick's Avatar
    I use llama and have a profile that sets my phone to silent at night. Since I only put the phone on the charger before going to bed it doesn't make any noise at all.
    10-07-2013 11:09 AM
  24. jamontoast1291's Avatar
    So I deleted the wireless charging sound, but now it just plays a different notification when I put it on the charger (the default notification sound from settings). It's a less annoying noise, but anyway to make it silent other than the llama/tasker workaround?
    EDIT: Just replaced the files with a silent sound file of the same name and it works, just an FYI!
    10-18-2013 04:00 PM
  25. jeep_man's Avatar
    Can you explain step by step how you did that?
    10-19-2013 08:12 PM
34 12
  1. Galaxy S4 help with Gmail Vibration
    By Barry Byrne in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-07-2014, 06:53 PM
  2. QI Pad that will charge nexus standing up
    By andy barton in forum Google Nexus 7 (2013) Accessories
    Last Post: 11-01-2013, 11:21 AM
  3. Do you own a Optimus G/Pro? Then help us!
    By the1m.polo in forum General News & Discussion
    Last Post: 08-29-2013, 08:52 AM
  4. need to get contacts out
    By karen ellis in forum Android Apps
    Last Post: 08-28-2013, 02:36 PM
  5. Crazy charging problems! I still have them and have had them for months even after unrooting!
    By AlbanianTechDude in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 08-28-2013, 02:21 PM
