1. anon154738's Avatar
    I'm using the LG qi wireless charging puck at night to charge my maxx, and apparently when the phone reaches a full charge it stops charging. This causes the battery stats to be off. Specifically the "time on stats" . My battery will show 100% but a time on of about 6 hours. Not a big deal, but it's nice to have a more accurate battery stats to work with. Anyone getting this problem?
    08-31-2013 07:34 AM
  2. alee's Avatar
    Yep... same here. Once it's fully charged, it will also not wireless charge until the battery has dropped a few percentage points, even if you take the device off and put it back on the pad again. Seems like a software issue.
    08-31-2013 02:07 PM
  3. JimBen73's Avatar
    Why would it continue to charge if its at 100%?
    Posted via my awesome, longer lasting phone than yours aka droid MAXX
    08-31-2013 02:50 PM
  4. alee's Avatar
    On other phones (e.g. SGS3) it will go to trickle and maintain charge, not be completely off charge. On the Maxx, you cannot maintain a charge at 100% by keeping it on a Qi charger. The phone starts discharging at 100% and will not start charging again until 95% or 97% (don't recall which it was).
    08-31-2013 02:57 PM
  5. Eclipse2K's Avatar
    I will have to pay attention tomorrow because I could swear my statistics are accurate. Then again I have the official Ghost charger so that may make a difference.
    Sent from my Motorola Droid Maxx using Tapatalk 4
    08-31-2013 06:38 PM
  6. Sportplumber's Avatar
    Do you notice it getting hot?
    Mine seems to get very hot on wireless charging (Ghost 100).
    Also in an Otterbox case.
    08-31-2013 08:55 PM
  7. jameskk1's Avatar
    I have the same issue using the Nokia Charging Plate. It doesn't really matter to me because I usually end up with 30-40% left over at the end of the day
    08-31-2013 11:23 PM
  8. Eclipse2K's Avatar
    This happens with the Ghost 100. I noticed it was off the charger for 10 minutes as soon as I removed it.
    09-01-2013 10:13 AM
  9. anon154738's Avatar
    No. Quite the opposite actually. Compared to plugging the phone in, it's quite cool. I don't have a case on mine though.
    09-01-2013 10:41 AM
  10. Zorro1's Avatar
    Can any of you who are wireless charging tell me if it still works with a few business cards in between the phone and charger? I like to stick a plastic case on the back since the phone's big enough and carry a few cards, and got to wondering if it would still charge...thx.
    09-10-2013 09:19 PM
  11. 18t's Avatar
    i just tried it with 6 notecards and it worked without issue. didnt try any more than 6 as you said a few.
    09-11-2013 12:32 PM
  12. Zorro1's Avatar
    Super! Thanks so much. Didn't want to buy the wireless charger if it didn't work. Really appreciate that.
    09-11-2013 12:47 PM
  13. jhlinka's Avatar
    Not only stats, but I use the maxx w/ wireless charger as a night clock, so when it stops charging, the screen shuts off because daydream is set to be on only when docked or charging. I might try and program an NFC chip to turn it to 'desk mode', which I've read activates daydream...
    09-11-2013 01:33 PM
  14. anon154738's Avatar
    Didn't think of that. That would be annoying! Just curious though, how do you see the clock in daydream mode if it's laying down? Propped up our something? Btw, for whatever reason this problem seems to have fixed itself. Battery stats are now accurate. It seems to still trickle charge on and off I've noticed in the morning when it's full. Doing so gives me accurate stats!
    09-11-2013 02:33 PM
  1. samsung Note2 wont charge
    By sweeeeetheart in forum Samsung Galaxy Note 2
    Last Post: 01-03-2015, 07:21 PM
  2. LG MS770 Android SWYPE keyboard issues keying in fields
    By skiogawa in forum General Help and How To
    Last Post: 09-09-2013, 05:17 AM
  3. Touchscreen issues
    By phildev74 in forum Samsung Galaxy Note 8.0
    Last Post: 09-04-2013, 11:56 AM
  4. galaxy note 2 wont charge
    By sweeeeetheart in forum General Help and How To
    Last Post: 08-31-2013, 01:18 PM
  5. Default SMS App Issue
    By acswee in forum Samsung Galaxy S4
    Last Post: 08-30-2013, 11:29 PM
