Page 1 of 4 1234 LastLast
Results 1 to 25 of 76
Like Tree9Likes
    Default another battery post
    Came from g2 to maxx. Is this good battery life? Off charger at 630am and its not 605pm.
    How do I post screen shot on to the mobile app?
  2. #2
    Default Re: another battery post
    Dont think you can post screenshots via android central app. Have to use tapatalk forum app
    Sent from my HTC One
  3. #3
    18t
    18t is offline
    18t's Avatar
    Posts
    Global Posts
    294 Global Posts
    Don't know what your numbers are but everyone's results are different based upon their own usage.
    Here are the numbers from gsam battery meter
    73% left
    21% battery used 7:38:45
    41% Screen time 2:00:59
    24% phone 48:56
    2% Bluetooth 7:40:34
    22% app usage
    6.6% WiFi 7:41:51
    Thoughts? Is this good for the maxx?
  5. #5
    aue123's Avatar
    Posts
    Global Posts
    159 Global Posts
    battery meter is jacked up, 73 + 21 is 94.. but looks okay to me
  6. #6
    tpdtopcop's Avatar
    Posts
    Global Posts
    79 Global Posts
    Why did you come from g2 to maxx? G2 is supposed to have good battery life also.
    Quote Originally Posted by tpdtopcop View Post
    Always like Motorola and g2 wasn't that great battery and signal was bad
  8. #8
    Snareman's Avatar
    Posts
    Global Posts
    1,143 Global Posts
    ROM
    Stock
    Quote Originally Posted by conan1071 View Post
    I briefly had the G2 as well. How do you like the Maxx in comparison?
  9. #9
    srkmagnus's Avatar
    Posts
    Global Posts
    7,445 Global Posts
    ROM
    Stock 4.4 (KitKat)
    When you are replying or posting a message there is a camera icon in the lower right corner. Click that and you'll have options to take a photo or upload an existing one.
    Let us know if you have further questions.
    Sent from my GT-P7510 using AC Forums mobile app
  10. #10
    Quote Originally Posted by srkmagnus View Post
    Those options look like they're only available on the tablet version of the app. My android central app doesn't look like that on the MAXX.
    EDIT:
    I just found that there's also an Android Central Forums app as well that's based on tapatalk. Ok, that's where you can post the pictures. Interesting...
  11. #11
    You have to take a screen shot NY pressing Power + Volume Down first. Then when you're typing a message there should be either a paperclip icon or possibly 3 dots and click one of those.
    Sent from my Motorola Droid Maxx using Tapatalk 4
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by Snareman View Post
    The g2 was a good phone and if I was on att, it would be the phone to get. The maxx so far is awesome. Haven't lost a 4g signal at all and I think battery is going to be amazing. I don't know how anyone can not like this phone.
  13. Thread Author  Thread Author    #13
    Don't have that on the mobile app on my maxx
  14. Thread Author  Thread Author    #14
    OK got the forum app. See screen shots taken as of 10:30 CST and phone was off charger yesterday at 7am and turned off last night for about 7 hours. Is this good battery?another battery post-1380339088733.jpganother battery post-1380339108253.jpganother battery post-1380339120568.jpganother battery post-1380339129501.jpg
    Sent from my XT1080 using AC Forums mobile app
  15. Thread Author  Thread Author    #15
    another battery post-1380341720001.jpganother battery post-1380341756543.jpg
  16. #16
    Yes, that's good battery.
  17. #17
    Had Verizon G2 had phone not answering issue which they supposedly fixed with update. So far so good with Maxx. Still have 2 weeks left to return. But think I'm sticking with Max.
  18. Thread Author  Thread Author    #18
    Charged overnight and now look At battery. 6% loss in under an hour?another battery post-1380370028711.jpg
  19. #19
    aue123's Avatar
    Posts
    Global Posts
    159 Global Posts
    Default
    7 hours screen time and 3 hours talk.. you should return that phone. you should be getting 22 hours talk and 47 hours screen time. . stop trolling. I don't know of any phone on the market that does that.. an hour of screen time for 6% .. asking if that's good? 60% 10 hours screen time..
    Posted via The Maxx
  20. Thread Author  Thread Author    #20
    Quote Originally Posted by aue123 View Post
    Posted via The Maxx
    Trolling? I have this phone, still within 14 day exchange period and want to make sure the battery is good. From what others post, their battery life seems better.
  21. #21
    Depending upon what else is going on and brightness level, 6% percent loss in an hour of screen time is pretty darn good.
    Thanked by 2:
  22. #22
    Charged overnight and now look At battery. 6% loss in under an hour?Click image for larger version.
    I read your Private Message so I'm responding to that and the quoted image. The image I quoted is actually normal because it depends on when you remove it from the charger. A phone doesn't actually continue to charge once it's at 100% so it will drain. You may get a trickle charge but it's so little that it will drain. The phone will generally show 100% at this point but it could realistically be at 95% so the first 10% isn't exactly the best way to gauge your overall battery life. Although you losing 6% with nearly an hour of screen time isn't bad either way you look at it.
    Your other images are excellent. You were on Wi-Fi it appears so the numbers are inflated from where they would be on 4G LTE but you definitely have a battery that works the way it was intended.
    Thanked by:
    conan1071 and aue123 like this.
  23. Thread Author  Thread Author    #23
    Off charger 6am CST Saturday and now its 9pm Sunday. See screen shots. How do I stop android os from using 10% of the battery? Does this also mean I can talk for another hour before the battery is totally dead?
    another battery post-1380506401416.jpganother battery post-1380506412309.jpganother battery post-1380506421656.jpganother battery post-1380506430466.jpg
  24. #24
    My best to date.
    Motorola M70>Samsung N400>Sanyo MM7500>Sanyo A900>Blackberry Pearl>Blackberry Storm>HTC ThunderBolt>Nexus 4>Motorola DROID Maxx
  25. #25
    Turn off the things running in the background used by this process. Turn off touchless access, active notifications, and widgets that update in the background, any apps that update in the background that put data into notifictations. Turn off Google Now.
    Or, keep those things on and be happy that you have one of the few phones that can keep all of those things on and not be dead in less than a day.
  1. My S3 is draining rapidly, even w.new battery
    By keybladeofhearts in forum AT&T Galaxy S3
    Last Post: 03-04-2014, 06:44 PM
  2. Replies: 2
    Last Post: 09-26-2013, 04:16 PM
