Results 1 to 6 of 6
    pappy53's Avatar
    Posts
    Global Posts
    2,072 Global Posts
    ROM
    Stock
    Default Wireless charging with Defender
    I am wanting to get an Otterbox Defender for my Maxx, and I already have the Ghost 100 wireless charger. Has anyone had any experience with this combination, as to whether it will charge with this case on the phone? TIA!
    "Liberals claim to want to give a hearing to other views, but then are shocked and offended to discover that there are other views." - William F. Buckley, Jr.
  2. #2
    Default Re: Wireless charging with Defender
    I have seen someone here claim that it works fine. The only concern I would have is how much heat the Defender traps in.
    Sent from my XT1080 using Tapatalk
    pappy53's Avatar
    Posts
    Global Posts
    2,072 Global Posts
    ROM
    Stock
    Quote Originally Posted by Eclipse2K View Post
    That is a concern. Thanks!
  4. #4
    I have a tylt charger and the otterbox-defender doesn't effect mine at all. I haven't discovered by otter box to be hot after charging. My phone gets hotter talking on it a while then it does while charging.
    I like mine together. I can't answer about the Ghost 100 but I would say it would be about the same.
  5. #5
    It works, but I find the increased gap from the rubber case both causes the phone to heat up and it takes FOREVER for it to charge!
    I had my phone for a 2 weeks before I received my otter-box and had the charge pad the whole time. Before it would charge just as fast as plugging it in but now in the time it takes for the phone to charge on a wall charger it gets maybe 30-50% on the pad. Honestly I would say it works but you will probably find it more convenient to undo the bottom plug and use the charger than spend 2-3x as long waiting for it to finish charging.
    But if you do want to, the heat from the pad is no more than using the phone under heavy load, nothing to be alarmed about.
  6. #6
    Moo Cow's Avatar
    Posts
    Global Posts
    191 Global Posts
    Quote Originally Posted by Ben_on_fire View Post
    Thank you for your insight. I guess all things considered, I don't see this as something worth getting if it takes that long to charge with the Otterbox Defender on. I am fine with using the wall charger, which won't be used every night. Now, if I had to charge this phone every night? Might be a different story. But to me, it's not worth the extra price for a convenience that isn't as convenient due to the case protection I have chosen.
  1. Note 3 - While wireless charging phone won't ring
    By ezridermn in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-08-2013, 03:25 PM
  2. Can't Answer Calls With Voice (But Can Reject Them)
    By My-kl Embryon in forum Samsung Galaxy S3 I9300
    Last Post: 12-05-2013, 08:01 AM
  3. what will I loose with nova
    By techie5 in forum LG G2
    Last Post: 12-04-2013, 08:02 PM
  4. Help- With 4.3 how to move apps to SD card
    By wburleson in forum Sprint Galaxy Note 2
    Last Post: 12-04-2013, 04:18 PM
  5. Remove Daily Stains with 911 Emergency Stain Clean
    By jennifermundy2 in forum Android Applications
    Last Post: 12-04-2013, 04:32 AM
B
