Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
Like Tree4Likes
  1. #26
    skatergirl's Avatar
    Posts
    Global Posts
    2,829 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Apps that don't work (or don't work right) on Kit Kat
    Quote Originally Posted by jfriend33 View Post
    My ten year old used handcent. Isn't that for kids?
    Sent from my XT1080m using Tapatalk
    Handcent is for everyone. Has a ton of features.
  2. #27
    skatergirl's Avatar
    Posts
    Global Posts
    2,829 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by DefectiveWeeble View Post
    Awesome. I'm glad the devs are working to get it resolved for us. Let us know how it works out for you, if you don't mind! In the meantime I've been using Textra, which is pretty nice, but I still want to go back to Handcent.
    Sent from my XT1080 using Tapatalk
    Handcent sent me this upgraded app and now everything works as it did before the KitKat upgrade.
    Attached Files Attached Files
  3. #28
    CattieBrie's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by skatergirl View Post
    I think this version is in the app store this morning. I am still looking for a good texting app; I am going to give this a try.
  4. #29
    skatergirl's Avatar
    Posts
    Global Posts
    2,829 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by CattieBrie View Post
    Oh ... good that the update is in the app store. I like Handcent because of its features and customization options. It offers a bunch of skins and one of my favorite options is the delay in sending. I have mine set at five seconds in the event I am sending to the wrong person (I am sure we have all done that) or I notice a big typo. I can stop it before it goes. I also like that I can schedule texts in Handcent.
  5. #30
    clarker07's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something Jelly
    Has anyone else had problems with motorola connect since the update? Mine hasn't been able to connect at all.
  6. #31
    tcmeiss's Avatar
    Posts
    Global Posts
    191 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by clarker07 View Post
    Yeah. Mine did the same thing. I finally turned it off.
    Also, Wordament doesn't appear to work with ART...
    Sent from my Droid Maxx
  7. #32
    xweb10's Avatar
    Posts
    Global Posts
    697 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CNA
    I did notice the Yahoo! Sports app does not work well when using ART, as opposed to Dalvik. I tested this on my Nexus 7, but I assume the same for my MAXX.
  8. #33
    PWav's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The text message alert stopped working on my Panasonic KX-TG78xx home phone system after I upgraded to KitKat 4.4. When I look at the Bluetooth settings for that device, sometimes MAP shows and is checked, but usually MAP doesn't even show up - just the 'Connected to Phone Audio.' But, even when the MAP shows as connected, the text alert still doesn't work on the Panasonic KX-TG78. Even if I install the workaround app - 'Text Message Alert' -from Panasonic the Panasonic phone still doesn't alert. The phone audio feature thru the Panasonic still works fine, though.
    I know the Panasonic phone text alert feature works ok, because my girlfriend's iPhone 5 still text message alerts on the Panasonic.
    Also, on my car, phone audio, music over Bluetooth, and text messages displaying on the Nav screen all work ok.
  9. #34
    adamhudson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just received the kk update and using nova prime. That home screen disable fix is not working for me.
  10. #35
    Snareman's Avatar
    Posts
    Global Posts
    1,935 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by adamhudson View Post
    What home screen disable fix?
    Sent from my Droid Maxx using Tapatalk 4
  11. #36
    adamhudson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's in the first post of this thread
  12. #37
    doogald's Avatar
    Posts
    Global Posts
    4,690 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is working for me. Nova settings. Gestures and buttons. Home button. Select "None". Turn off "Only on Default screen" below it.
    skatergirl and LOTL2 like this.
  13. #38
    Justin Stepp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got a good glitch. I prefer to use the Facebook website instead of the app and now you can no longer post a picture to Facebook. When you select to post a picture you are given two options:
    take a new one with your camera
    Or
    Use a document viewer which fails
    You can longer select a picture using the gallery of even photos app.
  14. #39
    CrazyRussian007's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Justin Stepp View Post
    Or
    Yes you can. Select "Documents" on the first prompt and then you will be given more options: Google Drive, Images, Downloads, Photo, Gallery, and more options depending on apps you have installed
  15. #40
    Lyle J's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Received 4.4 update this morning and Fancy Widgets 5.5.5 is not working properly. Selecting the forecast on the widget opens the full weather app but now it's overlaying my default screen. Also, pressing the hour on the clock no longer opens the alarm app.
    Also having an issue with Apex Launcher Pro 2.2. Pressing the home key is supposed to bring up screen previews. It does but doesn't go back to my default screen like it did before the update.
    So far these are the only issues I've found. Have sent an email to the Dev.
  16. #41
    doogald's Avatar
    Posts
    Global Posts
    4,690 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lyle J View Post
    Yes, there is one bug that causes a single tap of the home key to report to the system that you have pressed home twice. It happens in all launchers. See the first post of this thread for the fix: http://forums.androidcentral.com/mot...ml#post3334911
  17. #42
    Unobtanium's Avatar
    Posts
    Global Posts
    537 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    EasyTether still works. Requires a USB cord, but it works.
  18. #43
    Lyle J's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by doogald View Post
    Thanks! I missed that. Is this a bug with Apex or KK?
  19. #44
    DOOG9517's Avatar
    Posts
    Global Posts
    293 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That fix doesn't work for Action Launcher (pro). I used to be able to hit home to toggle the quick drawer. Now if I hit home it only brings me back to the default home screen. Its a long reach for one handed operation to open the quick drawer!
  20. #45
    russel5150's Avatar
    Posts
    Global Posts
    1,274 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The static wallpaper app is not working. It says it has a fix for kit Kat but it keeps force closing when I try to set a wallpaper... Guess I need something else because I hate the background scrolling!!!!
    Sent from my XT1080 using AC Forums mobile app
  21. #46
    tcmeiss's Avatar
    Posts
    Global Posts
    191 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by russel5150 View Post
    This this one:
    https://play.google.com/store/apps/d...dev.wallpapers
    PicSpeed. It allows you to set the wallpaper in either scrolling or static. Seems to work for me in kit kat with ART.
  22. #47
    tcmeiss's Avatar
    Posts
    Global Posts
    191 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And now this just started happening. Every time I try to scroll down in the settings window for the AC Forums app, it does this...
    Attached Thumbnails Attached Thumbnails Apps that don't work (or don't work right) on Kit Kat-1389754028750.jpg
  23. #48
    russel5150's Avatar
    Posts
    Global Posts
    1,274 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks tcmeiss I'll go try it now
    Just tried it. It won't let me pic from my gallery
    droid maxx
  24. #49
    tcmeiss's Avatar
    Posts
    Global Posts
    191 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    droid maxx
    Try long pressing the home screen and selecting wallpaper. It should come up as an option there.
  25. #50
    Masheen's Avatar
    Android OG
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    As of 4.4 Google changed its permissions for third party battery and wake-lock detector apps to access and report information. There are two ways to fix this, one being to root the phone, and the other is to follow these steps on an unrooted phone:
    https://docs.google.com/presentation...dit#slide=id.p
  1. Moto G - 4.4.2 Kit Kat Upgrade starting today
    By strav22 in forum Moto G (2013)
    Last Post: 10-15-2014, 07:48 AM
  2. Replies: 6
    Last Post: 01-24-2014, 11:01 AM
  3. Using LTE and voice on Verizon note 3 on tmobile
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 12-19-2013, 11:02 PM
  4. How do i open apps on Tab 3?
    By jds1990 in forum Samsung Galaxy Tab 3
    Last Post: 12-19-2013, 07:29 PM
  5. Note 2 in app pics horrible
    By Curton in forum Samsung Galaxy Note 2
    Last Post: 12-19-2013, 05:40 PM
