01-15-2014 01:53 PM
50 12
tools
  1. phissure's Avatar
    For those that are pondering the switch I'd like to start a thread so people can see which apps work and don't work (or kind of work). I'll try to update this thread when others post issues.
    Updated: 14JAN2014
    Launchers:
    Apex Launcher: Pushing home key acts like a double tap. Disable the home key action to fix it.
    Nova Launcher: Pushing home key acts like a double tap. Disable the home key action to fix it. (skatergirl)
    Apps
    Chomp SMS: Can send txts with it, but it wont show the txt i sent or the txt responses I get back (Billy Sweeney)
    EasyTether: See FoxFi.
    Fancy Widgets: Selecting the forecast on the widget opens the full weather app but now it's overlaying my default screen. Also, pressing the hour on the clock no longer opens the alarm app. (Lyle J)
    FoxFi: No more wifi tethering. They say that it will not work with Kit Kat. This may change in the future if they figure out a way to make it work. You must use bluetooth or USB tethering.
    Go SMS: showing my sent texts twice, but recipient correctly gets only one (pappy53)
    GSam Battery Monitor: Doesn't Work (pappy53)
    Hancent: Can send txts with it, but it wont show the txt i sent or the txt responses I get back. Double sends texts.(skatergirl) UPDATE: App updated
    Rainy Days: Double tap zoom doesn't work (lmdroid)
    12-19-2013 05:26 PM
  2. skatergirl's Avatar
    Good idea for a post!
    12-19-2013 05:45 PM
  3. drvier8's Avatar
    Wakelock Detector and gsam battery monitor didn't work on moto x with kit kat. I assume they won't work on the maxx (not that you'll need them).
    12-19-2013 07:20 PM
  4. ulnek's Avatar
    actually handcent works... just messages are all dated december 31, 1969 and it will reorder your messages with mms showing up as persistently the newest thing you've received. switched to go sms for now, which is working well.
    12-19-2013 08:09 PM
  5. pappy53's Avatar
    GSam Battery Monitor doesn't work. Go SMS is showing my sent texts twice, but recipient correctly gets only one.
    12-19-2013 11:42 PM
  6. SeigaGen's Avatar
    Whatsapp...
    If u switch to ART.
    Sent from my XT1080M (Droid Maxx) using Tapatalk 4 Pro
    roscko likes this.
    12-20-2013 12:11 AM
  7. DefectiveWeeble's Avatar
    Same on mine for Handcent. Grrr. Only workaround I found is to delete all the picture messages, but that is tedious at best and shouldn't be necessary.
    Sent from my XT1080 using Tapatalk
    12-20-2013 02:32 AM
  8. ClintRo's Avatar
    It will just take a little time for the developers to update the apps.
    12-20-2013 06:28 AM
  9. lmdroid's Avatar
    Double tap zoom doesn't work on Rainy Days app.
    12-20-2013 06:45 AM
  10. skatergirl's Avatar
    I am emailing back and forth with the Handcent developers. Hopefully they figure it out. I like the Handcent features and don't want to be stuck with Hangouts. I also don't want to delete all my threads in Handcent just so I can find all my new messages.
    12-20-2013 07:06 AM
  11. AustinAggie's Avatar
    Has anyone tried Textra? Does it have the same issues as Handcent or Chomp SMS? (I don't have KK yet... )
    That's the app I use for texting - clean look (including a dark theme) and very fast. Not as many customization options as the others, but looks good out of the box. The stock SMS app is one of the few disappointments on this phone.
    12-20-2013 07:58 AM
  12. DefectiveWeeble's Avatar
    Awesome. Hopefully they get it fixed fast. I'd much rather be using handcent. Add of right now I'm using Textra. It's alright, but I miss the customization of handcent. Textra isn't having the issues though.
    skatergirl likes this.
    12-20-2013 12:34 PM
  13. doogald's Avatar
    FWIW, the stock text messaging app from 4.2.2 is still around. Hangouts is just an option.
    12-20-2013 02:06 PM
  14. skatergirl's Avatar
    My problem is I like the customization that comes with Handcent.
    12-20-2013 02:59 PM
  15. doogald's Avatar
    Right. I was just responding to your "don't want to be stuck with Hangouts" comment...
    12-20-2013 03:05 PM
  16. phathands's Avatar
    Launchers:
    Apps
    FoxFi: No more tethering
    Hancent: Can send txts with it, but it wont show the txt i sent or the txt responses I get back (skatergirl)
    Good thread idea.
    Broke native tethering for those us who did the moto root method.
    Broke motoroot (for those of us who never uninstalled it). It had continued working after the last update.
    Need dat tethering back asap (ideally for free).
    Sent from my DROID MAXX
    12-20-2013 03:46 PM
  17. skatergirl's Avatar
    I just stated using Textra. It doesn't have all that Handcent has, but it is much better than Hangouts.
    AustinAggie likes this.
    12-21-2013 01:50 PM
  18. Snareman's Avatar
    YES!!! Its very annoying! Hope they get that taken care of. Wasn't sure why that was suddenly happening until I figured it was KK. Glad to hear its been reported to Handcent.
    12-21-2013 02:00 PM
  19. Einsteindks's Avatar
    Car Home Ultra was uninstalled somehow, and GSA battery has a fix, but it requires root.
    fat-fingered and Maxx-ed out.
    12-21-2013 02:39 PM
  20. hm841's Avatar
    Not necessarily:
    https://code.google.com/p/android/is...etail?id=62293
    RivertonPaul likes this.
    12-21-2013 04:38 PM
  21. Zorro1's Avatar
    Anybody try an Airplane widget for on/off?
    12-22-2013 11:45 AM
  22. phissure's Avatar
    I received a beta version of the handcent app from the developers that should fix some of the problems. I am sharing it on my Google drive acct here.
    DefectiveWeeble likes this.
    12-23-2013 10:15 PM
  23. DefectiveWeeble's Avatar
    Awesome. I'm glad the devs are working to get it resolved for us. Let us know how it works out for you, if you don't mind! In the meantime I've been using Textra, which is pretty nice, but I still want to go back to Handcent.
    12-23-2013 10:57 PM
  24. jfriend33's Avatar
    My ten year old used handcent. Isn't that for kids?
    Sent from my XT1080m using Tapatalk
    12-24-2013 08:30 AM
  25. phissure's Avatar
    Handcent is for texting
    Sent from my XT1080 using AC Forums mobile app
    12-24-2013 09:21 AM
50 12
  1. Moto G - 4.4.2 Kit Kat Upgrade starting today
    By strav22 in forum Moto G (2013)
    Last Post: 10-15-2014, 06:48 AM
  2. Replies: 6
    Last Post: 01-24-2014, 10:01 AM
  3. Using LTE and voice on Verizon note 3 on tmobile
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 12-19-2013, 10:02 PM
  4. How do i open apps on Tab 3?
    By jds1990 in forum Samsung Galaxy Tab 3
    Last Post: 12-19-2013, 06:29 PM
  5. Note 2 in app pics horrible
    By Curton in forum Samsung Galaxy Note 2
    Last Post: 12-19-2013, 04:40 PM
