Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Snareman
    Default LED Notification With Kit Kat
    Does this work? Or is it like it was with 4.2?
  2. #2
    Snareman's Avatar
    Posts
    Global Posts
    1,041 Global Posts
    ROM
    Stock
    Default Re: LED Notification With Kit Kat
    Quote Originally Posted by comptech520 View Post
    What LED? The Maxx doesn't have an LED.
    benjamminh likes this.
  3. #3
    Quote Originally Posted by Snareman View Post
    The Maxx has a white LED in the upper left corner that lights only when the battery life is too low to start the device. It's an indicator to plug into power ASAP. I don't think that anybody has found a way to use it for general notifications.
  4. #4
    I've never seen that led, then again I haven't been able to kill my battery in a a single day
    Posted via my awesome, longer lasting phone than yours aka droid MAXX
  5. #5
    Moo Cow's Avatar
    Posts
    Global Posts
    193 Global Posts
    As a former droid 4 owner I miss the LED light. However I will live. the active screen notifications are pretty nice.
  6. #6
    I've drained my battery. Haven't seen the light.
    Sent from my XT1080m using Tapatalk
  7. #7
    LabRat's Avatar
    Posts
    Global Posts
    138 Global Posts
    From the manual:
    •Low Battery LED: This LED lights up when you plug in your charger and the smartphone’s battery level is too low to power on the display. It means that your smartphone is charging and will be ready to use shortly.
    Sent from my Nexus 7 using AC Forums mobile app
    Thanked by:
  8. #8
    Snareman's Avatar
    Posts
    Global Posts
    1,041 Global Posts
    ROM
    Stock
    Quote Originally Posted by Moo Cow View Post
    While active notifications is really nice, I miss being able to look at my phone from across the room to see if I had any messages.
  9. #9
    Agreed, but at least the Pebble (or other smartwatch) is great for notices.
  10. #10
    Can you control google play music with the pebble? For example volume control and forward or repeat.
  11. #11
    Quote Originally Posted by JimBen73 View Post
    For volume control, you can use the app Music Boss for Pebble, which allows volume controls. You can also use it to switch between various music apps on your phone (so you can switch from Play Music to Pandora to Plex, etc.) The stock Pebble music controls allow you to choose one app that you can control, and it will not change volumes.
  1. KIT-KAT??
    By ryobi43 in forum Droid RAZR MAXX HD
    Last Post: 03-29-2014, 08:37 AM
  2. [App] Manage your photos with pixmeknot app
    By BombAppromotion in forum Android Applications
    Last Post: 01-08-2014, 02:06 PM
  3. OUYA - Help with a decision
    By Josh Frye in forum OUYA
    Last Post: 12-27-2013, 11:52 AM
  4. OTA notification still popping up
    By Spongey1313 in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 12-25-2013, 12:16 PM
  5. UK charger with US Nexus 7
    By Barge82 in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-23-2013, 05:40 AM
B
