1. Adam21221's Avatar
    Ever since the update... My Bluetooth works for making phone calls.. But not for playing my music... Car says.. No media device detected.. It's a 2012 sonata... It all worked fine before the update.... I've tried all I know to do... Any help????
    01-16-2014 08:50 PM
  2. DASHAUS's Avatar
    Go into the Bluetooth settings and bake sure it's set for phone and media on your phone
    Sent from my XT1080 using Tapatalk
    01-16-2014 08:51 PM
  3. Adam21221's Avatar
    Yes. Both are checked
    01-16-2014 08:57 PM
  4. LabRat's Avatar
    Did you unpair and then pair?
    Sent from my Nexus 7 using AC Forums mobile app
    01-16-2014 09:01 PM
  5. Adam21221's Avatar
    Sure did... Even deleted phone from car.. And car from phone .. still nothing
    01-16-2014 09:02 PM
  6. phathands's Avatar
    Any firmware updates for your car's Bluetooth?
    Sent from my DROID MAXX
    01-16-2014 09:12 PM
  7. Adam21221's Avatar
    I'm not sure... Did the dealership need to do that?
    01-16-2014 09:16 PM
  8. DASHAUS's Avatar
    Not usually
    01-16-2014 10:15 PM
  9. Adam21221's Avatar
    I also noticed... It won't even play music out of the speakers.. Have to put in ear buds to hear music
    01-17-2014 05:27 AM
  10. doggy2965's Avatar
    Try resetting phone if doesn't work then do factory reset. I had same problem on Razer with switch to ICS. Reset worked
    01-17-2014 06:07 AM
  11. LabRat's Avatar
    You wouldn't happen to have the Text Plus app installed, do you?
    01-17-2014 06:10 AM
  12. Adam21221's Avatar
    No text plus
    01-17-2014 06:32 PM
  1. Apps open when I am talking on the phone
    By Other Foot in forum Samsung Galaxy Note 3
    Last Post: 10-05-2015, 11:07 AM
  2. Nexus 5: Yet Another Signal Issue Thread
    By luke31 in forum Google Nexus 5
    Last Post: 10-03-2014, 07:15 AM
  3. Came from Windows Phone
    By HarisA1 in forum Introductions
    Last Post: 01-19-2014, 07:14 AM
  4. Sprint S3: Phone Security preventing root
    By laceylee1881 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-17-2014, 07:47 PM
  5. My battery is not all that good
    By emscapt47 in forum Samsung Galaxy S4
    Last Post: 01-16-2014, 07:53 PM
