Results 1 to 15 of 15
    shaselai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Droid MAXX: Umm, normal battery usage?
    So i used my maxx for one day officially off the charger at 7:30 and 1% at 7:30pm... i used little bit of google, bit of maps in the evening and most of the day with bluetooth on streaming music from phone.. Also some texting and wechatting ...is this usage too much for this phone to handle or the battery will get better?
  2. #2
    mustang02's Avatar
    Posts
    Global Posts
    664 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Umm normal battery usage?
    Install GSAM battery and see what is using up the battery. I can go over 2 days without a charge listening to slacker, texting, emails, etc.
  3. #3
    ryanr509's Avatar
    Posts
    Global Posts
    854 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Heres my results so far today. Off the charger around noon on WiFi from about 12-230 and from 230-730 on 4g LTE. Still at 86 % battery with around 1 hour of screen on time. Its been on for about 7.5hrs total so far. No BT no GPS. Auto screen brightness. Basically texting Facebook, web browsing, snap chat, instagram.
  4. #4
    ryanr509's Avatar
    Posts
    Global Posts
    854 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here's my battery usage for today. Unplugged at about noon on the 27th and still going strong at 60% only about 2-3 hours of this was on WiFi. The rest was in 4g LTE. This mainly used for web browsing, texting, Facebook, snap chat, instagram, clipboard, and the AC forums. Watched a few YouTube videos and that's about it.
    Sent from my XT1080 using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails Droid MAXX: Umm, normal battery usage?-1390906002405.jpg   Droid MAXX: Umm, normal battery usage?-1390906014885.jpg
  5. #5
    yenyob's Avatar
    Posts
    Global Posts
    143 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's hard for me to get a good read because the area where I work has horrible cell coverage and wifi is very weak. So my signal is always in the red. If I don't charge my phone during the day, my battery will be gone by the evening. However, if it was any other phone, it would be dead after 4 hours. The smart thing for me to do is leave the data off, but my phone us like my arm... It's figuratively attached to me.
    shaselai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok. So almoat dead again...Dont know how to attach photo but 35% screen. 15% mediaserver. And 10%idle...is this normal
  7. #7
    ryanr509's Avatar
    Posts
    Global Posts
    854 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My maxx is still going from being unplugged on the 27th at about noon. Heres some screenshots of my battery stats to conpare. Also I have GPS Bluetooth all turned off. WiFi was on the whole time but only connected for probably 12hrs and the other 18hrs was on 4g LTE. Also this includes about 7 hours if sleeping.
    Also auto brightness and Not a lot of streaming either.
    Attached Thumbnails Attached Thumbnails Droid MAXX: Umm, normal battery usage?-1390956312703.jpg   Droid MAXX: Umm, normal battery usage?-1390956322357.jpg
  8. Thread Author  Thread Author    #8
    shaselai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the mediaserver looks sketchy... i did have 4g and bt on the whole day... still the battery is disappointing!!!
  9. #9
    doogald's Avatar
    Posts
    Global Posts
    4,716 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by shaselai View Post
    Mediaserver is what is playing your music. If you tap screen, what is the screen on time?
    It looks like wechat is consuming a lot of battery as well.
  10. #10
    marlin29311's Avatar
    Posts
    Global Posts
    369 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It looks like you could possibly have your GPS polling a lot as well - do you have the GPS set on?
  11. Thread Author  Thread Author    #11
    shaselai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i didnt have time to listen to music... yes my BT,GPS,WIFI on all day ... One thing I HATE about wifi is (maybe theres a fix for it?) i keep getting connected to random wifis when i have it on when i dont know how to access them... is there a way to have wifi only connect to ones i can have access to?
  12. #12
    doogald's Avatar
    Posts
    Global Posts
    4,716 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Settings / WiFi. Tap the menu control on the bottom-right. Hit "Advanced". Turn off the top option, "Network notification".
  13. Thread Author  Thread Author    #13
    shaselai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    does gps use a lot of battery? i was on googlemaps navigation for 30 mins while listening bt music and was down 10% battery. the screen was on whole time though.. is this normal?
  14. #14
    an21281's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes GPS uses a lot of battery, esp. With the phone/screen on. I only have it on when I need to use navigation and turn it off immediately after when I'm done...
    Sent from my XT1080 using Tapatalk
  15. #15
    doogald's Avatar
    Posts
    Global Posts
    4,716 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    GPS only uses battery when it's used for location. You can leave the radio on and it will not drain battery until an app looks for location.
  1. Do I need Battery Doctor or Clean Master?
    By cristianocr7 in forum Verizon HTC One
    Last Post: 06-03-2016, 06:42 AM
  2. Show Battery Percentage
    By Faiz Anka in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-01-2014, 09:32 PM
  3. Replies: 6
    Last Post: 01-28-2014, 01:55 PM
  4. Replies: 1
    Last Post: 01-27-2014, 06:50 PM
  5. Excruciatingly bad battery life - please help!
    By Jake_15 in forum Samsung Galaxy S II
    Last Post: 01-27-2014, 01:55 PM
