1. qonic's Avatar
    reading the reviews about the car mount for the maxx it wasn't good..........has any body recently bought one did they improve it sinse 2013 ?
    i'm still thinking of getting one just to have something that will hold the maxx.
    03-12-2014 11:29 AM
  2. Einsteindks's Avatar
    Yeah, take your Maxx, test-fit the generics. They can only be better.
    fat-fingered and Maxx-ed out.
    03-12-2014 11:53 AM
  3. T-Rob's Avatar
    I've got one and it works just fine.
    Thanks,
    Chief
    03-12-2014 02:30 PM
  4. Jay Sacks's Avatar
    The Griffin mount works better than some of the reviews you see. It is not the quality of the older Motorola mounts for the Droid x's.
    Sent from my SCH-I605 using Tapatalk
    03-12-2014 06:00 PM
  5. qonic's Avatar
    I got the griffin at Verizon 40.00 but I registered on Isis so I only paid $3.44 for it.your right I don't see what all the fuss is I will take it apart to see where the wires run so I can drill holes for the camera,the neck could have a larger arch so the phone would tilt more flat and with a case on phone I will trim down the rubber on the cradle.
    03-12-2014 10:43 PM
  6. doogald's Avatar
    I had two issues with it - the included USB connector would not charge the phone with a case on (I'd have preferred just leaving an opening for my own cable if I wanted ti charge) and the suction mount released a couple of times when I was using it. I've switched to something more generic (I've also ordered a wireless charging dock from Indiegogo, which should be here next week.) Assist driving mode and touchless controls make a special car dock mode rather unnecessary, at least for me.
    03-13-2014 11:04 AM
  7. qonic's Avatar
    I had an old droid x car mount that I grinded down the ball so it will fit the small griffin socket now I can fully tilt the phone down.
    03-13-2014 09:40 PM
  8. drvier8's Avatar
    03-13-2014 11:09 PM
  9. ::Montgomery::'s Avatar
    I picked up a Scosche universal mount and it works great.
    Scosche Mobile Windshield and Vent Mount Kit: GPS & Navigation : Walmart.com
    03-14-2014 07:20 AM
  10. qonic's Avatar
    UPDATE!!
    After the success with the mount switching I got it on my dash while driving the phone moves because of the arm being a lot longer so I guess I'll grind the ball down on my bionic
    Car mount and it shouldn't shake while Driving and still able to tilt the phone down more.
    03-14-2014 12:48 PM
  11. qonic's Avatar
    Way better now with the bionic mount base on the griffin and trimmed some of the rubber so the phone with the cover on it goes on smoother.
    03-15-2014 01:15 PM
  12. AustinAggie's Avatar
    Agreed. It works ok, just doesn't feel that great/solid from a quality perspective. It does not work with a case which isn't great but I can live with, I don't use a case most of the time.
    03-16-2014 12:43 PM
  1. HTC One Car Questions
    By Yourmum90 in forum HTC One M7
    Last Post: 03-14-2014, 12:38 PM
  2. Micro card will not stay mounted
    By StlDean in forum Sprint Galaxy S III
    Last Post: 03-13-2014, 01:42 PM
  3. Coolest place in car to store phone accessories?
    By magirific in forum Verizon Galaxy S III Accessories
    Last Post: 03-10-2014, 03:22 PM
  4. Replies: 0
    Last Post: 03-09-2014, 12:45 PM
