Results 1 to 9 of 9
    Snareman's Avatar
    Posts
    Global Posts
    1,222 Global Posts
    ROM
    Stock
    Angry Phone won't stay in vibrate or silent mode
    I can't get my phone to stay quiet. I'll put it in vibrate or silent mode and it will take itself out of it shortly after. I'm stock, non-rooted. It sucks if I'm going somewhere where I NEED to be quiet but don't want to turn my phone off.
    Ideas?
  2. #2
    Default Re: Phone won't stay in vibrate or silent mode
    Perhaps notifications and alerts have different settings? In what menu are you putting it in vibrate or silent mode?
    fat-fingered and Maxx-ed out.
    Snareman's Avatar
    Posts
    Global Posts
    1,222 Global Posts
    ROM
    Stock
    I tried doing it several ways. I tried it from a control widget and then also uninstalled that and tried to just by holding the volume down button. The vibrate or silent icon will show up in the menu bar and then shortly after will just disappear and the phone will start making noise again. Occasionally it will work for a little bit of time and then stop working.
    Sent from my Droid Maxx using Tapatalk 4
  4. #4
    Find out what apps are running. Chances are an audio-based one is, and screwing with you.
  5. #5
    I am having the same issue. I believe it had something to do with responding to texts/answering calls that makes the phone take itself out of silent/vibrate.
    Snareman's Avatar
    Posts
    Global Posts
    1,222 Global Posts
    ROM
    Stock
    Mine fixed itself somehow. I checked all the apps I had running and it was still doing it even after I stopped everyone that I thought could be affecting it. I debated whether it had anything to do with a podcast app I installed.
  7. #7
    i have the same issue and cant find a solution....seems to happen when I receive a call, it then turns off vibrate and goes to ring,,,,any suggestions????
  8. #8
    If you have done a hard start (press and hold Vol down & Power for 15 seconds and the phone restarts) and that has not fixed it look for a 3rd party app that could be causing your issue. Since non of us no what you have installed it is hard to tell you which one.Go to Settings,Apps, and look at running apps. it could be an audio app or a tasker or possibly a scheduler that may be making the phone revert back to a non silent/vibrate mode.
  9. #9
    Start your phone in safe mode to see if it still do it. To start phone in safe mode, hit the power button and then press and hold power off
  1. Syncing Outlook Email with Android Phone
    By jimglinsky in forum Samsung Galaxy S4
    Last Post: 06-05-2014, 08:53 AM
  2. Band 12 phones coming to T-Mobile q4
    By dpham00 in forum T-Mobile
    Last Post: 03-15-2014, 01:52 PM
  3. how or where
    By bcouncil09 in forum General Help and How To
    Last Post: 03-15-2014, 11:48 AM
  4. Phone Temp in Status Bar
    By p3ntyne in forum Google Nexus 5
    Last Post: 03-15-2014, 01:39 AM
  5. Replies: 0
    Last Post: 03-14-2014, 10:04 PM
