Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By B. Diddy
  • 2 Post By Umass021
  • 2 Post By LeoRex
    Default Battery Question Around 10%
    Hi i was wondering if anyone else knows if this is normal for this phone or not. I've already had 3 Droid Maxx's do this 2 of which were mine and 1 which is my father's. At around 10% maybe 8% the battery suddenly drops to around 4% or so. Also while charging at around 5% it will jump up to around 10%. Sorry i didn't get any pictures of it jumping up while charging.
    Attached Thumbnails Attached Thumbnails Battery Question Around 10%-screenshot_2014-02-10-22-03-29.png   Battery Question Around 10%-screenshot_2014-02-07-19-34-45.png   Battery Question Around 10%-screenshot_2014-02-04-23-58-52.png
  2. #2
    Default Re: Battery Question Around 10%
    My unscientific guess based on nothing is that when the battery is that low, the monitor starts to lose accuracy. In general, it's a good idea not to let the battery get that low anyway ...
    brian7751 likes this.
  3. #3
    Umass021's Avatar
    Posts
    Global Posts
    1,591 Global Posts
    Carrier
    Stock
    I have seen my battery gain power when it gets that low. I think the post above says it all when it loses accuracy on a low battery.
    Sent from my XT1080 using AC Forums mobile app
    B. Diddy and brian7751 like this.
    Thanks. So low battery is bad for li-ion & polymer i didn't know that. I thought it was better too run it down. Learnin something new everyday. Hey is it still good to run the battery down every once in a while though.
    Also if i can recall correctly i don't remember this happening with Jelly Bean only after i updated to Kit Kat.
    It's weird is it android's standby. Because it seems like the battery works more efficiently when using it compared to letting it sit. Sorry i might not have worded this correctly to the thoughts of what is pertaining in my mind. Here is screen shots of good battery life.This was mostly just browsing the web though.
    Attached Thumbnails Attached Thumbnails Battery Question Around 10%-screenshot_2014-03-17-03-33-47.png   Battery Question Around 10%-screenshot_2014-03-17-03-33-43.png
  7. #7
    There's no benefit to running down a lithium battery. And you're right, if you completely discharge a lithium battery, it's dead and can't be recharged. So as a general rule, don't let it drop below 10-15%.
  8. #8
    Li-ion batteries don't discharge linearly... If you took a 2000mah battery and put it under a constant load...the voltage drops quickly at first, levels off a bit, then hits a point where the voltage drop speeds up. The software compensates and tries to scale things properly, but you'll still see the 'level' drop quicker when the battery is very low. I don't have a graph listing voltage vs percentage... if I did, I could probably tell you exactly when you'd see things pick up. But a 1% drop at, say, 75% probably is much different than a 1% drop at 20%.
    It's just how Li-ions discharge.
    brian7751 and B. Diddy like this.
    Here is some screenshots i just took of it jumping up while charging.It stopped jumping at about 10%Click image for larger version.
ID:	110517Click image for larger version.
ID:	110518Click image for larger version.
ID:	110519Click image for larger version.
  1. question about set app as default on Nexus 5
    By ntamim2006 in forum Google Nexus 5
    Last Post: 04-04-2014, 11:23 AM
  2. Various Sprint HTC One (M8) Questions.
    By adrianq in forum HTC One M8
    Last Post: 04-01-2014, 05:54 PM
  3. Just some questions
    By WildCatBBN3 in forum AT&T LG G2
    Last Post: 03-31-2014, 11:17 PM
  4. HTC One (M8): Blinkfeed Question
    By TazzRawr in forum HTC One M8
    Last Post: 03-31-2014, 09:37 PM
