1. doogan123's Avatar
    guys..
    So another issue that i would love help on is WiF and when it connects
    I have WiFi at home and in the office. However once I leave any of these locations, I notice that WiFi tries to connect to other networks ..as its suppose to ..but if I am just out if range or not authorized... It won't work...but While uts trying ...it also has my mobile data disabled.. And I have no functioning connection. I have to stop what I an doing and disable WiFi... Then remember to reenable when I get back.
    I have played with the setting for weak connections and that does not help
    I have tried a couple of the task application's ..Llama etc and they butchered my battery life...to do what I needed with precise locations you need GPS on. Using the tower locations did not help
    Am I asking too much? Ideally if the moto assis should do it...when it detects you driving... Shut off WiFi... But I cannot see how to. There used to be an application in mybikd droid that did this perfectly... Cannot remember the name now but I know it no longer works on this version on droid
    Any thoughts ..thanks
    04-06-2014 07:37 AM
  2. kandrelly's Avatar
    I have the same problem and I would love to be able to solve this. :-(
    04-06-2014 08:40 PM
  3. doogald's Avatar
    Well, in settings / wifi, turn off 'notify me when wifi is available'. While you're there, hit the menu lower right, tap advanced, and turn off "scanning always available".
    The assist app will not toggle wifi, no.
    04-06-2014 10:03 PM
  1. Brand new Galaxy S4 not auto connecting to Wifi
    By Joedm45 in forum Samsung Galaxy S4
    Last Post: 04-07-2017, 03:32 AM
  2. need help with my tablet
    By Sarah Mccracken in forum Acer Iconia A200
    Last Post: 06-11-2014, 02:56 PM
  3. Need Help: Japanese Galaxy S5
    By Hellbound in forum Samsung Galaxy S5
    Last Post: 04-07-2014, 10:23 PM
  4. PLS HELP need root thread 4.1.2
    By Lj Lj in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-07-2014, 04:06 PM
  5. HTC One (M8): WiFi arrows constantly lit up
    By zipro in forum HTC One M8
    Last Post: 04-06-2014, 01:33 AM
