Results 1 to 2 of 2
    Default Droid MAXX: power button and camera
    For some reason when I push the power button the camera turns on. This happens only when the phone is "off". Any thoughts? Thanks.
  2. #2
    Default Re: power button and camera
    I've never seen this. Is there a chance that you are doing the twist to open camera gesture at some point when you are not actively using the phone (like, when it's in your pocket or a case) and the screen is turning the camera on and then powering off without you being aware? Or does this happen even if you turn on the display, press home to go home, turn the display off and then on again? I suppose to check for this, turn on the camera, drag right from the left edge to open the settings, swing the settings arc up to the lowest entry and turn off the shake to start camera gesture and see if that stops your problem.
    The only other thing I could think of is settings / accessibility / double tap home is set to "Camera". There is a known bug in the KitKat build where a single key home press is mistaken for a double press, but that doesn't happen in this case - I just changed that setting to camera and it took a true double-tap to get it to open, so that's not the cause.
  1. Galaxy S5: How do I turn off the camera's shutter 'click'?
    By BubbaMac in forum Samsung Galaxy S5
    Last Post: 07-19-2015, 01:12 PM
  2. Suggest a camera app
    By thehyperone in forum General Help and How To
    Last Post: 02-09-2015, 01:28 AM
  3. No Google Playstore after rooting and installing CM11 (M5) Nexus 7 (2012) Wifi Model
    By Zahir Younis in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 04-17-2014, 08:48 AM
  4. 3 Days with the M8 and 3 Days with the S5
    By thegrants82 in forum Samsung Galaxy S5
    Last Post: 04-16-2014, 12:36 PM
