1. Xanth269's Avatar
    So I know there is an issue with bluetooth devices and the MAXX, my Jabra Wave died went to a VZW store and only option was a Plantronics Voyager, Jabra out of stock and needed something.
    When using the Jabra it would flutter but hold the call, the Plantronics with disconnect after 20 seconds I have to pick up the phone and turn on the speaker keep talking than it will reconnect to the BT.
    I have removed and reconnected the device. I like the features of the Plantronics unit but its annoying. Do you think its a defective unit or still a MAXX / BT connectivity issue.
    Any suggestions on a BT head but, I need something that wraps and feels good, I wear it for 8-9 hrs a day ans I am always driving from 1 job to another.
    Thanks,
    Dave
    06-25-2014 05:32 AM
  2. perkdog65's Avatar
    I have a Plantronics Voyager and use it all the time with my MAXX and I don't have the problem that you describe. The voyager has sensors that detect if you are wearing it or not so make sure you have it fitted good in you ear, especially if you are wearing glasses or sunglasses. It might not be detecting that it is being worn and disconnecting.That's the only thing that I can think of. It took me a little bit to get the right foam piece and get it to fit in and against my ear. Hope this helps ya.
    Xanth269 likes this.
    06-25-2014 07:04 AM
  1. Bluetooth not fully functional?
    Last Post: 09-02-2014, 10:50 PM
  2. [HELP] Unblocking SPRINT Samsung Galaxy S5
    Last Post: 07-11-2014, 06:46 AM
  3. Bluetooth not fully functional?
    Last Post: 06-27-2014, 05:38 AM
  4. Help Me Please!!!!
    By buddylove13 in forum Samsung Galaxy S3
    Last Post: 06-25-2014, 10:37 AM
  5. Replies: 1
    Last Post: 06-25-2014, 01:10 AM
