Results 1 to 7 of 7
    beeare's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Touchless Control Call Issue
    I'm running Art on the new 4.4.4 update and have an issue when trying to make a call using the Touchless Control feature, saying OK Google Now to make a call.
    There is a setting that allows your call to start up on speakerphone automatically when using this feature to initiate a call, but since the update, it does not jump into speakerphone like it used to.
    I've checked the settings and nothing has changed.
    Can anybody else tell me if they are experiencing this issue?
    Sent from my XT1080 using AC Forums mobile app
  2. #2
    stpac's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Touchless Control Call Issue
    I have the exact same problem. I use this feature frequently, and it worked fine until the update. I have wiped the cache and played around with the Touchless Control settings to no avail. I have not tried a factory data reset yet.
    If this is a Touchless Control issue, then perhaps Motorola can issue a fix through the Play Store. Maybe we should post in the Motorola owners forum.
  3. #3
    Series335's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same issue here!
    Sent from My MAXX
  4. #4
    WallaceD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use an app to control my speakerphone activation on calls. (The cleverly named "Speakerphone Control" is what I use.) It works great and is pretty flexible.
    I never realized Touchless Control has it's own setting on this. I disabled the app and enabled the control in TC... and it didn't work for me. I'm not running ART, though. I guess it's a bug.
  5. #5
    copywrite's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This issue is finally about to be fixed.
    doogald likes this.
    beeare's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by WallaceD View Post
    How do you know?
  7. #7
    stpac's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good news--the latest OTA update seems to have fixed this issue.
    doogald likes this.
  1. At&t Samsung Galaxy i747 4G Issue
    Last Post: 03-03-2015, 11:39 PM
  2. Replies: 1
    Last Post: 02-27-2015, 10:17 PM
  3. Nexus 7 Freezing, turning off issue
    By darkmech in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-17-2014, 11:54 PM
  4. chromecast sound issues
    Last Post: 07-17-2014, 06:44 PM
  5. Smart Keyboard Pro issue
    By hockeymn25 in forum LG G3
    Last Post: 07-17-2014, 04:56 PM
