Results 1 to 4 of 4
    Default droid max volume
    i'm new to the phone so not sure if its broke or a setting . was lissening to i heart radio on my phone like the 1st week i got it and it was loud 3 days later i can bearly hear it
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: droid max volume
    Through headphones? Have you tried a different set?
  3. #3
    Press the volume buttons while you're listening. Does that help?
  4. #4
    You may have inadvertently turned down the volume for whichever speaker you are using(Bluetooth, head jack, speaker). While playing the music uses the volume buttons and see if you can adjust it.
    You can also go to settings, sound, and the top choice is volume. Tap it and you can adjust all the volumes from there
  1. Replies: 4
    Last Post: 08-29-2016, 01:13 PM
  2. Wi-fi app for Droid Maxx?
    By AACJ in forum Ask a Question
    Last Post: 08-13-2014, 03:48 PM
  3. Using Skullcandy Aviators with a Droid Ultra
    Last Post: 08-11-2014, 09:51 AM
  4. Ringtone & Notification Volumes are Muting on their own
    By MRHIGHSPEED in forum Samsung Galaxy S5
    Last Post: 08-11-2014, 08:42 AM
  5. My computer doesn't recognize my droid x!
    Last Post: 08-11-2014, 02:36 AM
