1. Jeffrey_L's Avatar
    I have a 2006 Acura TL that allows a phone to connect via bluetooth for calls only (not streaming for other audio). I assume it is a common interface for Honda around that year.
    My MAXX pairs fine, but when I make calls it does not use the connection. It says it is using it. The phone call screen has a selection button at the bottom that allows you to switch between the handset, speaker phone, or bluetooth. It shows bluetooth, but the audio is going through the handset.
    If I switch the call to handset or speaker, and then back to bluetooth, then the car will pickup via the bluetooth connection. But when I first make a call it does not connect.
    Any ideas?
    08-13-2014 03:05 PM
  2. jesta192's Avatar
    I think I've had this happen also. I'm not sure, but i think the same issue may be happening with my Bluetooth headset as well. I've been trying to use the new Commandr app, but every time I use it while my headset is connected, the audio quits coming through. If I shut off Bluetooth and turn it back on, it usually fixes it, but it is a problem.
    Anyone else?
    08-18-2014 09:14 PM
  1. Galaxy Grand 2 Bluetooth Issues
    Last Post: 10-22-2016, 03:03 AM
  2. Droid DNA Message's problems
    Last Post: 08-14-2014, 04:01 AM
  3. Bluetooth pair GS5 to Iphone 4 music
    Last Post: 08-13-2014, 07:50 PM
  4. Synch Issues on my G5
    Last Post: 08-13-2014, 07:41 PM
  5. Samsung Galaxy s3 EXTREMELY FRUSTRATING ISSUE!!!!!!!
    By samsungg3owner in forum Ask a Question
    Last Post: 08-13-2014, 01:30 PM
