I've been pretty hard on my Maxx recently and it's gotten some small contact with water and small dropping of the phone. It MAY be connected with a small dropping yesterday, but suddenly bluetooth isn't recognizing my ear device, and it won't connect to my home wifi.
WIFI
-- All other devices work on my home wifi
-- I "forgot" the wifi, tried to reconnect with the correct password. It says "connecting" and then reverts back to as if I hadn't connected. Now it doesn't even pick it up, even though the modem is right here.
-- I was able to connect with a starbucks wifi no problem. That is, **WIFI IS STILL WORKING IN GENERAL**
OTHER
-- Bluetooth doesn't work either. Not sure if it is just not finding my device or all devices. I will try to find out and update if that helps.
-- I did a factory reset on my phone, and no change.
-- I have a FIOS modem/router setup. If I have to do something to that can you be a bit specific? I'm a novice when it comes to WFP/WEP/WWF/WTF/etc, and I'm not even sure how to access the settings on my router/modem. Like, the guy just came in and gave us the password and I connected with my PC, Ipad, etc.
-- Last pieces of information: some of those times I got my phone wet the mp3 files would skip a few seconds, e.g. :01, :02, :05, :06, etc. Rebooting phone seemed to do nothing, it would just.... get better after a little while.
Please help I absolutely must have both of these things.
WIFI
OTHER
